Salta al contenuto principale
Repair information for network equipment including routers, modems, and shared storage.
Need help identifying component
I can’t find what kind of component the black one with 150 on it is.
I thought a condensator but i can’t find anything resembling.
Part of a Netgear prosafe m4100-50g-poe+ network switch.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @gmantunt
Normally there are some tell tale sign at the pcb components, e.g. C = Capacitor,
the picture, i would say is an inductor. It should be Label as L xx on the PCB
The number 150 indicates the value 15uH if im not wrong,
and btw what is the issues with this POE switch?
Punteggio 2
2 Commenti:
Thank you. It is indeed.
For reference to others in search:
After searching a bit on 'Inductor' and 'inductor coil' i found multiple 'ferrite inductor coil' pictures that look the same.
The PCB says L62 and L63 but i don't know what i can do with that.
The switch doesn't have much problems. One fan is broken but still spinning. It was grinding itself away as far as i can see and the switch is filled with nasty dust and plastic. So my goal is to clean it and replace the fans.
While taking it apart i found some spots with an oily substance so i started looking for broken conductors or something similar i.e. the source.
I saw the inductor and was unfamiliair with it. It was weirdly shaped and others looked better so this was a potential broken part.
da
btw inductors rarely fails..... main concerns are those electrolytic capacitors, esp can be found on power supply....
da
Preparati per le riparazioni future
It looks like a 150ohm inductor coil to me, or it may be 15uH like @salmonjapan said. Take it off of the board and check it with an ohm meter, and see for sure.
Punteggio 1
5 Commenti:
@nick ,
To my knowledge inductors are never marked as Ohms value as their reactance (AC resistance i.e. XL =2πfL) can change with frequency.
Their DC resistance will also be extremely low for that value of inductance as can be seen on this datasheet example for a 15uH inductor. It is in milliOhms
To measure its inductance you would need an LCR meter unless it tested open circuit with an Ohmmeter
Cheers
da
@jayeff yea right bro..... having a simple LCR meter is good though......
like for me ... have one cheap gm328a standby ...
inductance measure in henrys
da
@salmonjapan I've done ohms checks with my multimeter, but I consider it a rough guestimate to be double checked.
da
@salmonjapan
I built one from a kit about 20+ years ago but have noticed that there are more up to date ones available now
This (see item #6) or even this but I have little need these days to use one.
Cheers
da
@jayeff DMM is def a in a pinch option. Do not rely on it for dead on accuracy.
da
Aggiungi la tua risposta
gmantunt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 168
