Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
My PS3 Fat has the error code 8002F14E and is in an update loop
Edit: I searched my ps3 model (CECHH01) up, and apparently its a PS3 PHAT.
So my PS3 got stuck in an update loop while putting CFW on it and now it gets Up to 30% before it says this
An error occurred during the update operation
(8002F14E)
<Suggested Actions>
Press the power button on the front of this system until the system beeps.
Next, unplug the AC power cord from the electrical outlet.
After a few minutes, restart the system. The update will resume
automatically when the system is restarted.
if the update fails again, write down error code "8002F14E" and then
contact technical support for assistance.
So, I followed the first suggested action and it failed AGAIN. Also, The PS3 was unplugged and wasn’t touched for at least 6 months. I also don’t want to get it replaced because they are Pretty Expensive these days, and I don’t want to sell it because I want to keep it.
I also took the Blu-Ray Drive out of the console because it wasn’t working (I also tried the update with the Blu-ray drive attached, and it still didn’t work). Also, The Sentence “Wasn’t working”, in this case means it wouldn’t spin up or read.
I’ve tried forcing it to download the update off a USB and it still gave me the same error code
I also tried installing the OS on another PS3 with the hard drive that the dead ps3 used, and it installed successfully, but when I put the Hard drive back into the dead ps3, it still tries to update
Also, It gets pretty hot. probably like 29 degrees Celsius. I hope you guys can help me get my PS3 back up and running.
Questa è una buona domanda?
Punteggio 4
1 Commento
Aider moi ma PS3 ne passe pas 70%que me conseilleriez vous
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
How do I fix error code 8002f14e?
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Hi!
29 degrees is an OK temperature. I would fix the Blu-ray Drive first before you continue with the update. It could fail the update if the drive is not detected. Be aware, if there is no sign of life, it could be the PCB.. You could test it and see how it goes..
Punteggio 0
2 Commenti:
Ok. I'll get up to fixing the Blu-Ray drive.
da
Thanks! Please let me know if it worked or not, if possible.
da
'''Go to Control Panel - power settings.  Go to the advanced settings, expand the Sleep entry, and disable sleep and https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam hibernate on each of the options. Restart the computer to get the computer unstuck .
Punteggio 0
2 Commenti:
uhhh. thats not what i asked for but ok.
da
Hi Alex, this is regarding Windows and not the playstation OS.
da
8002F14E means the (BD)Drive was not found or disconnected, there was a CoreOS region failure, or there was a Revoke region failure.
Source:
https://www.psdevwiki.com/ps3/Error_Code...
Punteggio 0
I had this problem, I fixed this by checking the blueray loose part was the correct way up and i I removed the battery and put back in. My cables and clips were fine. Hope this helps.
Punteggio 0
error code 8002F14
Punteggio 0
Aggiungi la tua risposta
Kaelan Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 143
Tutti i Tempi: 10,967
