Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
How do I fix error code 8002f14e?
i was updating to the newest update and when it went to install it is there a way to get it to stop trying to install or reformat it for my ps3 again
Questa è una buona domanda?
Punteggio 5
1 Commento
How to fix 8002f14E
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
I looks like you get this error due to a hardware fault, most common is the BR drive. Anyhow there is a great forum on Llamma's site and a couple of fixes are floating around on youtube give it a try and see what you come up with. Good Luck
Punteggio 2
2 Commenti:
+ I liked the youtube one using the axe
da
As we all know, sometimes you have to revert to extraordinary measures
da
Mine 3.55 has that error but that thing that hold the ribbon cable contacts and it dont holds with tape :D any helps i will host all cod CLs if u give me a usefull help :D
Punteggio 1
1 Commento:
same smh my ps3 is on 4.75.3 dex rebug and it just said file is corrupt
da
Im having the same problem...as soon as my ps3 turns on it goes stright to a system update but every time at 43% it errors out every time...I cant even get into it to go to the settings any ideas???
Punteggio 1
1 Commento:
omfg sameeeee i desperately need help
da
Do the update manually and here is how you do it.
1. Find a usb drive that is larger than 168 MB and format that drive to FAT32.
2. A computer.
3. Download the newest firmware from the computer (2).
4. Go inside the usb drive and make a new folder which you call PS3, and under that you make another which you name UPDATE. Under that folder is where you keep the firmware (3).
5. Plug the usb drive into the ps3 and power it.
6. In the XMB go to Settings ---> System Update ---> Update via Storage Media.
Source(s):
PS3 Firmware
http://j.mp/9uWzDs
Partition Wizard Home Edition
http://adf.ly/7JCH
PS3 Manual - Update using a PC
http://adf.ly/7JD5
XMB
http://adf.ly/7JCj
Punteggio 0
i got the error 8002f14e what do i do
Punteggio 0
Aggiungi la tua risposta
Brian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 18,245
