Salta al contenuto principale
The Brother MFC-440CN is an all-in-one color inkjet printer with a photo bypass tray first introduced in 2001.
What causes Unable to print 51 error?
Brother MFC 440CN will not print, copy, scan, fax or turn off by the power button; have to physically unplug. When trying to print it acts as if it is going to before the errir pops up. Checked all possible areas for paper jam. It sounds as if the print head is not engaging not totally sure. Ink volume is fine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi,
The answers in this link may be of some help. I realize that it is not the same model as yours but it is the same manufacturer.
unable to print 51
Punteggio 1
1 Commento:
Hi mine is brother mfc-440cn saying unable to clean 51 so what did you do?
da
Parti e strumenti correlati
follow this https://www.easyink.co.nz/support/brothe....
Punteggio 0
Aggiungi la tua risposta
pretticute sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,668
