Salta al contenuto principale
Repair and disassembly guides for Brother printers.
unable to print 51
Brother MFC-665cw
what does unable to print 51 means
Questa è una buona domanda?
Punteggio 3
1 Commento
Thanks...unfortunately, the dinosaur was not able to be fixed. Tried all suggestions and finally took it to a professional and they told me it wasn't worth the cost to try and repair.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi
the following link may provide the answer.
https://www.easyink.co.nz/support/brothe...
Punteggio 2
1 Commento:
SOLVED
It worked!!! Thank you!
da
Risposta Più Utile
Machine off
- Switch on the machine while holding down the "Menu" button, until all the leds are flashing on/off: it's the "maintenance" mode.
- Press 80
- Press the "Mono start" button several times until you see "purge: xxxx"
- Press "2783" in order to reset the purge counter. You will see: "purge:0000"
- Press the "Stop" button.
- Press "99" to exit the maintenance mode.
This may or may not work but it's worth a shot.
Punteggio 3
2 Commenti:
da
This worked for me, thanks!!
da
Aggiungi la tua risposta
Camely Medina sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 18,878
