Salta al contenuto principale
"Problem with both trackpad and keyboard"
Both the trackpad and keyboard have not been working properly lately. I've rebooted the system a couple of times, but it only helps temporarily.
Using the macbook pro without the battery seemed to help for the first couple of days but I started to have the same problem, and it seems to become more consistent.
Any advise guys? I wouldn't want to pay a big amount of money to have it repaired. Hopefully it will not come to that. I will consider it as my last resort.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here is a link to a previous question on this subject that may provide you with the answer you need.
Pressure on case beside trackpad leads to cursor movement..
Punteggio 3
Parti & Attrezzi Popolari
Acquista tutti
Most likely either the battery or your top case to logic board cable. Here's how to reseat/replace the cable: MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment
Punteggio 2
Aggiungi la tua risposta
Marc sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,011
