Salta al contenuto principale
The Motorola Moto Z Play (model number XT1635-02, XT1635-01 and XT1635-02) is a droid smartphone that was released in September 2016. The Moto Z Play can be easily distinguished by the word “moto” placed at the top and the square home button placed at the bottom of the front of the phone.
20 Domande Visualizza tutte
Why will my phone not stay on?
So about a month ago, my phone started to cut off at 90% battery. I would try to cut it back on, and it would show the powering on screen, but would immediately cut back off. The chargers work, I’m sure of that. There are times that the phone will go through the powering on scenario, but cut off the second the home screen was visible.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @lanier ,
Does the phone stay on when the charger is connected and switched on?
If so it may be that the battery is failing under load and it needs to be replaced.
Here’s the ifixit Sostituzione batteria Motorola Moto Z Play guide which shows how to do this.
ifixit also sells the Moto Z Play Battery - Genuine but be aware there are battery shipping restrictions in place. The link was just to show you the cost of the part. There are other suppliers online that may suit you better. Just search for Moto Z Play battery to get results for suppliers
Immagine Replace a GL40 model battery compatible with the Moto Z Play smartphone. 3300 mAh. 3.8 Volts (V). 12.8 Watt Hours (Wh).
Prodotto
$32.99
Punteggio 0
Aggiungi la tua risposta
Leah Lanier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 73
