Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
"mobile data update failed"
hello my mobile iphone 8 plus says "mobile data update failed".
your iphone cannot make and receive calls or access mobile data until it has updated.
anyone any suggestions please.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
If you had to replace the back housing I would think the iPhone took a bad hit and it would be quite likely the issue was already there before replacement and/or the handling of the board made the damage just evident. No service flag with request to update is typical of a hardware damage to the logic board where the processor can’t find the baseband. It could be due to a number of components and will require deep microsoldering skills to be fixed. The only thing you can try is a DFU restore, but there are serious risks it won’t complete and phone will be stuck in restore mode until fixed.
Punteggio 2
Questa risposta era destinata originariamente a un'altra domanda.
The SIM socket is located on the logic board as marked here in Purple
You need a SIM held within it to tell the radio what bands your cellular carrier uses and can identify your phone.
If your SIM socket is damaged and/or the cellular radio logic is damaged as well as the connections to the antenna units then you can encounter inability to connect to the network.
Breaking parts is always a bad sign. Post a clear picture showing the damage and leverage the pictures within the iFixit teardown Smontaggio iPhone 8 Plus to identify the broken part/s so we can see more clearly what you are facing post a marked up picture as well Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine iPhone 8 Plus
Guida
Difficoltà:
Moderato
Punteggio 0
2 Commenti:
hello thanks fr ur reply., it says "mobile data update failed".
da
Can you identify the part you broke - Picture please
da
Try these steps:
  • Turning off Wi-Fi calling and Voice LTE may fix the problem
  • Open Settings and tap Cellular -> Wi-Fi Calling. Turn off the switch next to Wi-Fi Calling on This iPhone to turn off Wi-Fi Calling and go to Settings -> Cellular and tap Cellular Data Options. Tap Enable LTE -> Data Only to turn off Voice LTE. You’ll know Voice LTE is off when the blue checkmark appears next to Data Only.
  • Turn Airplane Mode Off And Back On
  • Turn Cellular Data Off And Back On
  • Check For A Carrier Settings Update open Settings and tap About to check for a carrier settings update. If an update is available, a pop-up will appear within about ten seconds.
  • Eject your Sim Card and Turn off Your Phone Once the device has been powered down reinsert the SIM and then power the device back up.
  • Reset Your iPhone’s Network Settings
  • Put Your iPhone In DFU Mode
Punteggio 0
1 Commento:
thank you, brother, for your reply, but i replaced the back glass myself and then it turned like this. and i settings about and in the carrier it says "no carrier" I tried all the above but still no use. do you think logic board has the problem?
da
i aleady change all housing body and now i have very low signal sometimes it says no service sometimes work good i open the iphone and hold with finger in the simcard socket and now works better but again i have sometimes problem i dont know what to do .
Punteggio 0
Aggiungi la tua risposta
uday maclean sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,057
