Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Power button not clicking after disassembling
Ok, so I was attempting to do a screen replacement on a iPhone 4 CDMA, and i wanted to disassemble the power button as it was not clicking before. However, once i took the physical power button apart and checked the power cable flex, everything seemed tip-top. Only problem i have is when i tried putting it all back together, after screwing everything back in and aligning the power button, as it was crooked, the satisfying click wasn’t there and I do not know why. I re-disassembled again and check the ifixit guide here to see if i didn’t miss a step or whatnot. Click was still not there. Is there like a part that i’m missing to get that click or do i have replace something to fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you place the small back plate in-between the cable and the plate ??
Punteggio 0
1 Commento:
there's a backplate sandwiched to the power button and the device?? I'm not sure, i have to check for myself
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Juan Jimenez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 62
