Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
How to fix the error 9?
the iTunes can not restore the ios because the error 9
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Have you jail broken it or attempted to?
Error 9 generally occurs during a firmware upgrade, and has something to do with a problem with the USB connection to your device that is causing it to unexpectedly disconnect when syncing.
It can be a hardware problem e.g. if the dock/lightning flex is water damaged or something.
Do all the basic stuff first:
  • Reboot your computer and try to restore again.
  • Use a different USB cable and port.
  • Check for dirt/junk/pocket fluff etc. in the lightning connector which could be preventing it connecting properly.
  • Disable any firewalls or security software which may be preventing access to the Apple servers.
  • Try restoring using a different computer.
You need to provide more specific and background info if you need more help.
Punteggio 1
1 Commento:
no jail broken
do not attempted to do that
da
Hi
Uninstall iTunes and reinstall from Apple direct website https://www.apple.com/uk/itunes/download... and step 2 use a different lighting cable .
And it should fix it and if it doesn't work it's a problem with your device
Punteggio 0
Aggiungi la tua risposta
usup wheelchair sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 179
