How to fix the error 9?
the iTunes can not restore the ios because the error 9
Questa è una buona domanda?
Have you jail broken it or attempted to?
Error 9 generally occurs during a firmware upgrade, and has something to do with a problem with the USB connection to your device that is causing it to unexpectedly disconnect when syncing.
It can be a hardware problem e.g. if the dock/lightning flex is water damaged or something.
Do all the basic stuff first:
You need to provide more specific and background info if you need more help.
no jail broken
do not attempted to do that
Hi
Uninstall iTunes and reinstall from Apple direct website https://www.apple.com/uk/itunes/download... and step 2 use a different lighting cable .
And it should fix it and if it doesn't work it's a problem with your device
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 178
