Salta al contenuto principale
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
What is LCD cable routing at LH hinge?
Dropped my laptop several times, broke a bunch of “nuts” , LH hinge separated from chassis, replaced the bottom case (chassis) and when I put it back together - no display. I think I crushed the LCD cable on the hinge as I don’t remember the routing and just laid it on top. Can someone PLEASE tell me the proper routing - over, under, around? Note: my 17” hinge is NOT the same as a 15”. The 15” looks to have a slot for the cable to sit in, not mine. Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Not sure if this is a help to you or not.
Here’s a image taken from p.72 of the service manual for your laptop. It seems to show the LCD cable going under (or behind depending on your point of view) the hinge.
(click on image to enlarge for better viewing)
Hopefully it may be of some help.
Punteggio 2
1 Commento:
I think it should go under also, but did not see a path in and out. I'll look more at your picture and look again at my hinge area.
da
Aggiungi la tua risposta
pusher44 gmcjb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 351
