Internet connection not working
My router is working fine but it cant get an internet connection. I've reset it multiple times
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 738
Hi @dgold44 ,
Has it worked OK before?
Can you connect to the internet when you are directly connected to the modem?
da jayeff
Yes it works perfectly fine then sometimes at night it just completely stops working.
da Dawson Goldsberry
Hi @dgold44 ,
Just to clarify, it is the router that loses internet connection not the modem, is this correct?
If it is the router is it still showing as connected to your computer, even though there is no internet connection?
Have you tried a different WiFi channel (change in router) just to see if it behaves the same?
Have you checked that your model router has the latest firmware installed?
da jayeff
