Salta al contenuto principale
Il router dual-band Smart Wi-Fi Linksys EA6900 è un router wireless a quattro porte con tre antenne sul retro del dispositivo. Il dispositivo è inoltre dotato di due porte USB (3.0 e 2.0) per l'archiviazione della memoria.
Internet connection not working
My router is working fine but it cant get an internet connection. I've reset it multiple times
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Hi @dgold44 ,
Has it worked OK before?
Can you connect to the internet when you are directly connected to the modem?
da
Yes it works perfectly fine then sometimes at night it just completely stops working.
da
Hi @dgold44 ,
Just to clarify, it is the router that loses internet connection not the modem, is this correct?
If it is the router is it still showing as connected to your computer, even though there is no internet connection?
Have you tried a different WiFi channel (change in router) just to see if it behaves the same?
Have you checked that your model router has the latest firmware installed?
da
Aggiungi un commento
1 Risposta
Hi Dawson,
This can be multiple things but you can try these following things:
-Make sure that the cable from the modem to the router is connected
-Reset the modem
-Try a diffrent ethernet cable from the modem to the router
Punteggio 0
Aggiungi la tua risposta
Dawson Goldsberry sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 1,016
