Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
TouchiD issues with new iOS?
I am a shop and have repaired 1000's of phones-
Anyone experiencing fingerprint issues with current iOS after screen replacement?
The phone shows no failed touchID message, just doesn't see the finger to scan.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Have you updated to 11.0.3?
Have you done a Settings --> General --> Reset --> Reset all settings (NOT ERASE CONTENTS AND SETTINGS)
da
Thanks for your reply
As I mentioned I’ve repaired 1000’s of phones. I know all about bad home buttons, dirty, or erasing and re-scanning.
The issue was on 3 different phones today all 6s. All normal everyday screen repair. iOS doesn’t show “failed”. It simply doesn’t see the scan. When trying to put a new print in it just sits and waits as if there is no finger on the button.
Current supplier says they have had calls on this issue over the last few days and are looking into it.
Hoping posting here I might get a quicker answer
Thanks again for your input
da
Aggiungi un commento
1 Risposta
When I upgraded to IOS 11 upon release, there was a known issue regarding TouchID that affected my iPhone 6, and I had to delete my saved fingerprints and re-scan my fingers to solve this.
However, it did give me a failed TouchID message when it failed. I would say try to re-scan your fingerprints first, if that doesn't work, there may be an issue with the print scanner in the home button, it could be worth replacing the home button.
Before commencing repairs or taking it to a repair service, make sure you take some basic steps such as cleaning the home button of dirt, grime, etc, and ensuring that both your finger and the button are dry.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
mazzolagregory sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 237
