Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
What is the choice kit?
What is the difference between the following kits
iPhone 6s Plus LCD Screen and Digitizer Full Assembly
vs
iPhone 6s Plus LCD Screen and Digitizer Full Assembly - Choice
Questa è una buona domanda?
Punteggio 1
2 Commenti
This question was migrated from http://www.ifixit.com/Answers.
da
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Both of these versions can come with or without tools. The main difference is as follows:
iPhone 6s Plus LCD Screen and Digitizer Full Assembly - This is an aftermarket quality replacement screen that includes the small parts (camera, microphone, sensors).
iPhone 6s Plus LCD Screen and Digitizer Full Assembly - Choice - This is an OEM quality level replacement screen that includes the small parts (camera, microphone, sensors).
Either way, iFixit stands behind their parts so if you do have issues, they will replace it. The Choice screen will have better glass, better color (better LCD) and more solid flex cables as well as being assembled with a cold press glue process which is superior to the hot glue process of the aftermarket screen.
IMO, this question should be on the Answers Forum and not Meta as it is of repair interest to anyone who wants to decide which parts to order for their repair. @mayer @oldturkey03
Punteggio 3
1 Commento:
@refectio let's make it so.
da
Parti e strumenti popolari
Acquista tutti
From what I can see, the only difference is that the iPhone 6s Plus LCD Screen and Digitizer Full Assembly includes the option for a fix kit, the other does not.
Punteggio 0
Aggiungi la tua risposta
sathish600 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 100
