Salta al contenuto principale
Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
memory card is not working
memory card stopped working and will not capture pictures.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Jim -
On your Menu is a selection for Format. Find it and select it. That will give you an option to format your memory card. Do that; re-formatting a memory card usually solves access problems.
Russ
Punteggio 0
3 Commenti:
When I open the format function, it is blank, there is no format function available. I get the reading, no card.
da
Jim - Have you tried a different memory card? -- Russ
da
Try removing the battery and let the camera stay without a battery for a few minutes. Then replace the battery and try again.
da
Parti & Attrezzi Popolari
Aggiungi la tua risposta
jimkerns1939 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 396
