Salta al contenuto principale
Repair, support and disassembly guides for camcorders designed by Flip Video.
Change date and or reset unit
I have one of the earliest flip camcorders. It works great, however when inserting new batteries recently, the change date screen came up.
I inadvertently closed the screen before entering current info.
Mfg. Pure Digital Technologies
Model: F160B
Holding power button in for 10 seconds does not work
No tripod mount, thus no reset hole
Holding the power button on while pushing the up arrow does not work
Removing batteries for any amount of time does not work.
Nothing on the internet for a F160B or just a flip 60 seems to work.
Date is stuck in 2006
This happened long ago, I fixed it, but for the life of me I cannot remember how I did it
Thanking you in advance for any help you can provide
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi there, I have the same problem now. Is there any chance you remember how you fixed this? Thanks so much
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
So I'm pulling the batteries, and will let it sit for a very long while. Hopefully any onboard batterey will discharge. We'll see.
Hawk
Punteggio 1
1 Commento:
mate... just dug out my old minoHD date wont pass 2020..
da
Preparati per le riparazioni future
Risposta Più Utile
Try this:
1) Power off the camera
2) Turn on the camera
3) When the logo appears, hold the record button, and "Set Language" should appear
This should allow you to go through the original configuration routine.
Punteggio 1
2 Commenti:
Didn't work. Sorry I didn't include this one in my description. I can say that everything on the internet regarding this has been tried, at least that I have found after hours of research. Thank you for your reply though!
da
I think this is the original flip, it even has the "DVD retail processing port" on top!
da
Aggiungi la tua risposta
Petrohawk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 23
Tutti i Tempi: 932
