Salta al contenuto principale
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
Synaptic touchpad not working
My touch pad does not work, driver not showing in device manager. I downloaded driver from Acer, it told me it was installed and ready for use, but still not in device manager,neither can I find where it installed. I also did a complete system restore, Any ideas please.
Questa è una buona domanda?
Punteggio 2
4 Commenti
i can go to mice and other pointing devices but I cannot found 'usb touchpad controller'.The options are only 'ELAN 12 C Filter Driver' and'HID Compliant mouse'
da
can anyone help me
da
my pc comes with windows 10, but i downgraded it to windows 8 and the mouse and sound wont work
da
can anyone help with a solution
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi
Have you tried pressing Fn + F7 together to 'toggle' the touchpad back on? (Fn + F7 turns the touchpad both On and Off)
Where did you check in Device Manager, was it under Mice and other pointing devices?
Also have you checked in Control panel > Mouse to see if the touchpad has been disabled there at all?
What OS is installed?
Update (03/12/2017)
Hi Terry,
Just a thought, see if the following is available
Go to Mice and Other Pointing Devices in Device Manager and see if there is a listing for a USB Touchpad controller.
Right click on the listing and select Update driver. When you get to browse my computer, you'll have the option to "let me choose" and then you select "usb input device" instead of "touchpad controller."
Also have you checked for 'hidden devices' in Device Manager, (located in the View tab option)?
Punteggio 4
2 Commenti:
da
excellent answer toggle Fn +F7 to get the mouse working again. Thank you
da
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Terry Eastwood sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 14,017
