Salta al contenuto principale
A microcontroller (also called an MCU for microcontroller unit) is a small computer placed on a single metal-oxide-semiconductor (MOS) integrated circuit (IC) chip.
How to use enbedded-microcontrollers?
Hey, boys and girls.
Yesterday I bought a MB90F882PMC-GSE1, an embedded micro controller manufactured by Fujitsu.
I'm so confused on how to use it, maybe it just a simple problem.
Your help will be appreciated. Thank you.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi,
Why did you buy it?
What did you want to do with it?
Here is a link to the datasheet for the controller. Perhaps this will help you .
http://html.alldatasheet.com/html-pdf/20...
da
I second @jayeff's question.
These need to be soldered on something to work. What purpose were you intending for these ICs?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The best thing to do is return it as you really can't do anything with a raw chip.
Maybe you want to look at a Rasberry-Pi system. Slide down to the lower section of the URL to see all of the devices you can get and the additional I/O modules. I have two I've been playing with.
The community and material here is just great to learn and build anything you can imagine!
Punteggio 3
Parti e strumenti popolari
Aggiungi la tua risposta
shayne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,060
