Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
Identify error 1 problem when updating.
So after about a month or two that i fixed my iPhone the problem started to reappear and i mean it started to Searching for service. So to permanent fix (the last time i fixed it with the hairdryer) this issue i would like to know if there an easy way to identify if the power management ic causes the problem or the baseband ic itself (as error 1 is related to hardware issues)
Also is there any difference error 1 with error -1?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If it was searching for signal the stopped working then I suggest that the modem has stopped working. You did the worst thing possible by updating. The phone is clarified by Apple and I bet that the phone does not have an imei. Therefore iTunes throws up error 1 or -1
Nothing Can be done to fix this
Punteggio 0
3 Commenti:
It was in the same situation when i i bought it and i then by accident it got working but the problem is that i don't know how!?!? Now i am trying to find a way to fix it again but this time once and for all. Also yes there is not an IMEI and the modem is blank( exactly what happened in the first place)
da
NO IMEI then no fix - Sorry
da
Even with reballing the ic?
da
Aggiungi la tua risposta
georgekarapi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 90
