Salta al contenuto principale
The most recent version of the Coolpix series, the Nikon Coolpix S5300, was announced on January, 2014. Repair of this device is similar to past models and will require tools such as a screwdriver and a plastic opening tool.
How do you replace a cracked screen?
My camera screen is cracked and I can't see my pictures, is there an easy and cost effective way to replace it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
If your camera screen is cracked and is affecting the functionality of the camera, or you simply wish you replace it, follow our simple replacement guide: LCD Screen Replacement Guide
Punteggio 0
5 Commenti:
Please do not link to content that does not yet exists, or is not publicly accessible.
da
@flyingdutchman these are student assignments and they are (most likely) still working on that guide. If you click on both OP and Riordan McCole and Rebecca Field's profile you will notice that they are both in the same program. Confusing but pretty common and the guide will eventually appear.
da
when i go to the the link above, says "you cannot view this guide"--why not ?
da
@kbroo these are student assignments and they are (most likely) still working on that guide. The guide will eventually appear.
da
I'm down voting this answer because it's of no use without the guide and it has not been posted in a timely manner. Riordan gets an F from me on his assignment.
da
Aggiungi la tua risposta
Rebecca Field sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 216
