Salta al contenuto principale
Nikon Coolpix S5300 LCD Display Screen Replacement
Cosa ti serve
  1. Nikon Coolpix S5300 LCD Display Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 2, immagine 1 di 1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: passo 3, immagine 1 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: passo 3, immagine 2 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: passo 3, immagine 3 di 3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 5, immagine 1 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 5, immagine 2 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 5, immagine 3 di 3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 6, immagine 2 di 2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 7, immagine 1 di 2 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 7, immagine 2 di 2
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 LCD Display Screen Replacement, Button Panel: passo 8, immagine 1 di 1
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 9, immagine 1 di 2 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 9, immagine 2 di 2
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  10. Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: passo 10, immagine 1 di 2 Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: passo 10, immagine 2 di 2
    • Carefully remove the screen away from the silver plate.
    • Carefully fold the screen over exposing the latch for the ribbon cable.
  11. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 11, immagine 1 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 11, immagine 2 di 3 Nikon Coolpix S5300 LCD Display Screen Replacement: passo 11, immagine 3 di 3
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  12. Nikon Coolpix S5300 LCD Display Screen Replacement: passo 12, immagine 1 di 1
    • Once the ribbon cable is disconnected, remove the LCD screen.
Conclusione
Waleed Chakir
Membro da: 03/04/16
301 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,716
