Salta al contenuto principale
A 16.1 MP Sony Mirrorless Camera with 16-50mm Lens released in September, 2012 and discontinued by the manufacturer.
How to replace faulty pop up flash
Pop up flash on my sony nex 6 pops up but no longer fires, and is faulty. Where can I get a replacement and how difficult is the task of replacing it?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Parts can be found on eBay but the question is if the mode and control dial still work? Why I ask is that there are sensors on the mode/control dial assembly that reports if the flash is down or up. Recently I broke part of the assembly which now my camera is stuck in manual and the flash won’t fire.
Punteggio 0
1 Commento:
I was able to fix the dial assembly and now the camera works as well as the flash works once more.
da
Aggiungi la tua risposta
james sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 732
