Salta al contenuto principale
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
Recover formatted partition in ROM
I formatted partition number 3, I have back up of it. But the device is never turn on after it, and it is not recognized by PC.
I guess I need to program the ROM memory.
How can I do it, and which tools, devices should I use?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hello Kostya Kostyushko,
  • Run Odin flash tool,
  • put your phone in to download mode (vol down/home/power button) and connect to PC via USB
* Tick re-partition box on odin tool
* Click PDA and select your stock official Samsung ROM
  • Flash and wait for reboot
You have to find Correct ROM and Odin tool for S5 Active.
Note : All data will be lost on your user data partition as you re partition the ROM & . Flash your device at your own risk.
Hope this answer help you to fix your dead S5
Cheers!
Punteggio 0
4 Commenti:
This is a problem as I mentioned in my question, the device is never turn on. It means, I can't put it to Download mode.
I'm not sure what the 3rd partition is responsible for, maybe boot loader? But it seems I messed up this time.
Even if I connect the charger, it is not have any reaction. Completely dead.
da
Yes. it must be boot partition. you need JTAG flashing solution to fix you phone
da
Can you explain please? Never worked with JTAG, but I'm sure I can handle it if you point me. Thank you.
da
its a big topic which can't be explain in 1024 characters. simply you can find your self on web and see the YouTube guides, title = JTAG Flashing
da
Preparati per le riparazioni future
Aggiungi la tua risposta
Kostya Kostyushko sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 804
