Salta al contenuto principale
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
Film not developing! Help!
Hello ifixit folk,
I was wondering what the best solution to getting film to develop would be? They are all turning out blank >_<.
Thanks lads!
-British Joey
Questa è una buona domanda?
Punteggio 51
30 Commenti
When I take a picture nothing comes out what do I do?
da
When I try to take a picture nothing comes out. I just bought the camera and i don't know what's wrong
da
I take the pictures but only so come out blank a my parents are mad because alot of those pictures are important .What do i do ?? (Urgent)
da
minr aren't developing either! its so not cool. there has to be someway for them to work! please let there be!
cheers!
sasha
da
i totallly agree with all you guys
luckily my film is coming out just not developing
i feel sorry that nothing comes out for u!
you poor guys!
da
Mostra altri 25 commenti
Aggiungi un commento
29 Risposte
Soluzione Prescelta
Hello Joseph from the UK,
We’ve made an extensive troubleshooting guide for film not developing issues on this camera.
If the film is developing blank, we recommend that you check to make sure the shutter is functioning properly and the light/five-mode dial is set to proper lighting. If the problem consists then replace the batteries. The other problem may be that the film you have has gone bad and at this point you'll need to buy a new batch.
Cheers!,
Richard
Punteggio 14
17 Commenti:
my instax film is coming out blank as well it is brand new film. i took a picture earlier and it worked then i tried taking more pictures and it is not working. On the back where you place the film it has a S and it goes to S and goes to 10. I was wondering what that ment? or how i can fix this problem please.
da
hi, my daughters instax too develop no pictures too, it turn out blank. What to do? thank u
da
My film is coming out blank as well. I just got my camera yesterday and it seems as every second one is not developing I am very disappointed.
da
I got my Fuji film yesterday and my pictures are turning out blank I'm very very mad about it!
da
Hey my pictures come out fine but for every picture there is either a blue yellow dot I don't know how to fix it
da
Mostra altri 12 commenti
Parti e strumenti popolari
Ours did the same thing and we realized that we touched the back part where your not supposed to touch. We tried another film pack and was very careful NOT to touch it and it worked. So maybe you made the same mistake we did. :)
Punteggio 11
3 Commenti:
im trying to buy new batch of film too.. because what you have said is i did.. i touch the back part of the film.. thanks i hope this will work :D
da
I took 1 picture and waited for it to develop . As i was waiting i took another and let them sit to develop . The first one stayed all white/blank and the second developed .. i don’t think touching the film was the problem . I always touch where it says not to touch . But i don’t put so much pressure on it . If that was the case i don’t think the second photo would’ve develop . But i also took 3 more pics and those to were also blank .. maybe i got a bad package ? I threw out the wrapper so I’m not sure if it expired ..
da
Well maybe that is the reason because since you touched the film then only the first one got messed up and it didn’t reach the second one
da
The most important thing is that one, you don't use expired film and two, you don't expose the film to light no matter what. Even if you open it in the dark, any hint of light will kill the film. Even if you are curious as to if the film is positioned correctly or if there is any film left, ignore that urge because you will 100% ruin your chance of your film developing.
Also, when the film pops out after the photo (make sure you don't open the back whatsoever!) turn it over so that the image that's developing isn't exposed. I'm not sure if this makes a difference or not, but I take no chances so long as the photo comes out!
The environment might also factor in, take that into consideration. If it's very cold or very hot where you are, your film might take longer to develop since it's so sensitive. The camera should be at a pretty average temperature so that it's at its prime.
I hope this helped!
Punteggio 8
1 Commento:
My pictures don’t eject at all, have replaced batteries trying to reset several times to no avail
da
The cause of the issue depends on what you mean by “not developing”. If the photo turns out all white then that means your film has been flashed - or exposed to so much light it’s no longer able to record a photo. Film works by being exposed to an image projected onto it through the camera’s lens while the shutter is open for a fraction of a second. Therefore the film must otherwise remain in total darkness until it gets pushed out of the camera, during which the packet that contains the development chemistry gets broken open and spread across the film by being squeezed through a set of rollers. The black card that sits in the front of the film pack and gets ejected the first time you push the shutter release is commonly referred to as a dark slide - it’s there to protect the film from light so you can load it without damaging it by exposure to light.
If the photo turns out all black, or some photos turn out all black and others turn out just fine, then your Instax camera has a defective shutter. For some reason, it jams just slightly and fails to leave an opening. The film ends up not getting exposed to the image and that’s why it turns out all black. This seems to be a recurring issue with the Instax Mini 9, and maybe other models too. The camera has a one year warranty so you can get a free replacement or repair from Fujifilm. Also contact them to get any film that was wasted replaced. Or return the camera to the store you bought it from for a refund if that’s their policy and buy yourself a replacement. That’s how I solved the issue with mine.
Punteggio 6
2 Commenti:
I forgot to mention - never ever ever under any circumstances remove a pack of film or open the back at all until you’ve finished shooting all the frames in the pack. Once that black card is ejected, the film will be vulnerable. Any exposure to light besides normal picture taking will ruin whatever film remains in the pack.
da
Hi, i am having the issue you described (the film developping all black), but the issue is i bought it second hand on vinted, although it was supposed to be good as new. Is there any way i could have access to any sort of warranty, or is there anything i can do ?
da
1- you may have squished or damaged the film
2- you may have left the film in a hot place and have messed with the chemical inside it
3- maybe the film was always just messed up since you bought it
Punteggio 5
1 Commento:
#3 scares me lol
da
Make sure that on the back of the camera there is a number and not an s. If there is an s, and you take a picture, nothing will come out, but if there is a number, it will use the film and take the actual picture.
Punteggio 3
2 Commenti:
Yeah but we're is the part that your not supposed to touch, because I tried but it just came out black with some spots white. I don't get it!!!!!!!!!!
da
Thanks this helped, even though I was pretty mad about it. Man, those films just cost so much.
da
Are you opening the back part after every failed picture? Ya I would stop. When you do that the camera goes back to S and will be trying to take off the back cover of the picture pack again, also not taking the picture.
Punteggio 3
Blank Films
3 of mine came blank
Answer-
  • take a few shots
  • wait
  • if not ,new film or battery's, AA
Punteggio 2
You got a bad batch. That happens when the film sits at the store to long.
Punteggio 2
Keep it in the dark to develop! If it gets exposure to light it won’t. Even if the camera is in the light. Also, don’t open the back after you put the film! Your film won’t work again.
Punteggio 2
Instax mini 8 cameras come with batteries that I believe are energizer batteries but if you read the manual/instructions it comes with then you will see that it says that alkaline batteries work best for it.
Punteggio 1
1 Commento:
My daughter uses her mini 8 with cheap "Topcraft" (Aldi) NiMH accu's. Works fine.
da
If you opened it before they were all gone, then they may have been exposed to sunlight and not worked.
Punteggio 1
Put it in front of a heater it will show up on the white side. I was having this problem so I tried heat and it worked
Punteggio 1
have you tried to put the polaroid photos in a dark spot such as a drawer or a dark room for a few minutes?
Punteggio 1
1 Commento:
All my pics were coming out black. Then I realized that I wasn't waiting to pull it out until it comes all the out and red light blinks near view finder. Once I waited for that and stopped pulling on it too soon, they all developed!
da
The reason might be either you opened the back and the film was exposed or it was to cold. You might be able to take a couple of pictures at first but eventually the photos will come out white/ undeveloped. The temperature has to be above 40 degrees fagrenheit and less than 104 degrees fahrenheit. Hope this helped.
Punteggio 1
It may be an issue with the camera, but if you have taken the film out of the camera after you already put it in, then the film is exposed and wont develop.
Punteggio 1
Hi Joey, I had this problem, too. I couldn’t find the solution online— first, I would check the shutter. It wasn’t the shutter in my case. There was a piece of black tape inside the camera, above the lens, blocking the exposure. Peel it off- problem solved for me. Hope it works for you too!
Punteggio 1
2 Commenti:
Hello, I have this exact same problem. How do you peel off the black tape?
da
how to you peel of the tape in the camera i think the tape is always been there i thnk
da
Hello I wanted to add an additional answer here as after two months and 3 packs of film I have finally solved my problem as to why every few pictures turns out fine but not always.
When I retract my lense into my camera (power down) the next shot out, the shutter doesn't open - ever.
To figure this out I opened my film hatch and took a few pictures without film to watch the shutter, experimenting with things like “blocking the flash with my hand” or “closing and opening the lense” and sure as sugar, the first shot after closing the lense would never trigger opening the shutter.
So now to power down my camera, I take the batteries out, and to make sure that my lense doesn't retract and cause the issue again, I wrapped several rubber bands around the lense, and use a protective cover on the end.
Good luck everyone and happy shooting!!
Punteggio 1
Change the batteries first. Worked for us. We installed the batteries that came with the camera. Even though it powered on and would feed the film, the pictures did not develop or came out totally black, white or a combo of both. Some had colored dots etc. Changing the batteries correct the problem, all pics now develop. Just incase you want to know we installed the energizer bunny! (-:
Punteggio 0
Their nothing wrong with the camera.
Its suppose to relate to the old fashion camera thats the whole point. The picture with be blank at first but got to give it a few minutes so the foto can cool off and the picture will appear. When your out side you put it on sunny mode and when inside the house or restrant put the camera on inside. Its amazing and i love it .. it just takes ime to be able to use it..
Punteggio 0
You take the photo and don't touch the blank part just touch the bottom part and shake it until it fully developed
Punteggio 0
1 Commento:
You probably shouldn't shake it because there will be a fold, also you have to let the film develop if you don't that will cause minor problems
da
It's maybe because you take the film box out while it still has film. Another reason might because while you are re putting the new film you touch or squeeze the parts where it says do not touch. I personally had this problem so I took out my film box even though it sill had film and was very careful not touching the parts where they stated do not touch, so after that all my pictures came out perfectly.
Punteggio 0
mine was cause i opened the back and they became exposed to light but after i took 4 pictures they started coming out again though the 4th had a spot of white in the corner
Punteggio 0
have you taken the film out. because if it has been taken out the light has touched it. you have to keep the film in when all of it has been used or they will tuen out all white or have white spots.
Punteggio 0
Ok so... something strange is happening. All of my pictures turned black after some seconds and were not developing at all.
The first film pack i bought...i thought it was damaged. So after wasting 4 films, I threw away that pack and tried another one.
Same thing happend with the second. Took 3 pictures and decided to remove it from the camera.
Bought a tird film pack and wasted around 3 pictures and the same
So, somehow...I decided to try taking a picture to the sky leaving the indoor setting to allow the camera to capture more light and guess what. That developed!
I read somewhere that maybe the camera was not taking enough light or something.... who knows.
so after the one I took to the sky... I tried taking another to a parked car and then that didn't develop. But then...the car was parked in a place that was not getting enough light so....
I stood up in the brightest place i found and then tried taking a selfie with the sun hitting my face directly but, still leaving the setting for indoors (the one with the little house) and THAT DEVELOPED TOO. My face looked really white because all the light but hey....it developed. It was not all black so that's something.
I took another selfie but with the sun not hitting my face this time. That didn't develop. (Still with the indoors setting...what is happening!?)
So.... Being all frustrated and angry i just decided to finish the whole film pack. I took another picture to the same parked car that was not getting all the sun light...and this time it developed. Then I took another selfie away from the sunlight and this time it developed. I took the last picture I had to some random place that was not very sunny and it developed too....
I have no idea why it worked after that... but I'm thinking.... once you turn on the camera....do you need maybe to give it some time to get warm up or something so it starts developing pictures?
Punteggio 0
3 Commenti:
I even tried using one of the film packs i previously used and removed from the camera since i kept it.... the first picture didnt develop. Im guessing because the light hit it after removing it from the camera but then... the pictures left after that one developed.
Each picture looked better than the previous one. Im really thinking this has something to do with the camera warming up.
I just bought a new film pack. I will try again and see what happens. Maybe i will turn the camera on and leave like that for a few minutes?
da
Ok this has been happening to me too, I think that as soon as you take the pic you have to immediately put it face down in a dark area because if exposed to light, it will not develop but I’m not 100% sure just making an assumption. I hope this helps!
da
Never mind, Dustin already answered and his was way more logical haha but thanks.
da
it’s because the film has been exposed to light before being used or the setting was wrong try matching the circle with the orange light on the front of the camera
Punteggio 0
My pictures start off white but if as soon as they come out you shake them a lot(like I mean for a long time) then the film will start to develop
Punteggio 0
1 Commento:
no, no,no, you do not shake them, that can actually ruin the picture, causing the chemicals to run to the outer corners and away from the main area
da
why does the mini 9 photos come out black and how do I fix it I have tried switching the camera out and find new film and still the results stay the same.
Punteggio 0
black pictures are a shutter problem, no light is getting in and how can it put the image on the film if it doesn’t open, or barely opens. Never shake the picture, it will splatter the chemicals around unevenly and cause defective developing. NEVER OPEN the film door unless it is showing a 0 that means it is out of film, or you will be the exposing the film by letting light onto the film and you will get all white pictures, since you are not supposed to be the shutter. It will also reset the camera pics left to 10, so once you shut that door, leave it shut. If you have some in there that you already opened on, It could be that only the next film will be ruined and some after that will work, so don’t just throw it all out. Flow chart: Camera needs film->open camera, insert film, now it says “s” - think of the s as meaning ‘shade’, telling you the shade is still over the film. Depending on the camera, some will automatically release the shade when you power on, if not, then the first time you go to take the pic, it will release it. It does this because you have just shut the door, so that is telling it that you inserted a new film pack. If you open that door again, it will think it needs to release the shade on a new pack, and put out a blank white film. OK, so you inserted the film pack and the shade has been released and the ‘s’ now becomes 10. From here your pics will count down till 0…. unless you open the door and it goes back to s, waiting to release the shade from a new pack that you told it was put in, because you opened that film door. If you open that film door, it will continue to go from s to 10, then back to s and release another white film, thinking it is the shade and back to 10. There is nothing to see inside, DO NOT OPEN THE FILM DOOR UNTIL IT READS ZERO! or you will reset your camera to s and start the beginning process over and over until all the film is gone and comes out white.
Punteggio 0
Aggiungi la tua risposta
Joseph Larwa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 106
Ultimi 30 Giorni: 579
Tutti i Tempi: 458,654
