Salta al contenuto principale
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
How do I fix a dead screen?
With no other indications the screen has stopped working completely, and it just showing black. Is it possible to replace the screen myself? If so, what part do I need to order and how do I open this guy to get in there and make that replacement?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Kode, first make sure that the issues is your LCD. Connect an external monitor and see if it displays correctly. If it is your LCD that needs to be replaced, follow this video
Punteggio 3
6 Commenti:
screen was hit by toy now shows a rainbow what do i do i just ordered a new screen///
da
Hi quireapril,
Click on the link 'this video' above in OT03's answer. It is a video that shows how to replace the screen in an Acer C720 Chromebook.
da
Hey, I followed this because I had a dead screen too. It's still dark, what do I do?
da
@Sean Davis you are not telling us what you did. I assume your computer is a Chromebook C720
da
Hello. How do I fix a computer monitor that won't turn on? It was perfectly fine yesterday but then completely won't work the next day. Whenever I plug in the monitor, its power button usually lights up red but now it doesn't. Does this mean it has a power issue?
da
Mostra 1 altro commento
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Kode sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,051
