Salta al contenuto principale
Released September 2011 12.2 MP Digital Camera with 7.1x Optical Zoom NIKKOR ED Glass Lens and 3-inch Vari-Angle LCD
Why is my camera not turning on?
Why is camera not turning on?
Questa è una buona domanda?
Punteggio 1
1 Commento:
I have a coolpix p7700. Been using it for at least 3 years with no problems. 3 months ago I turned if off and since then it has refused to turn back on. Nothing seems to work including replacing the battery. Their is no damage to the camera. To old and expensive to send out for repair. Any suggestions??
da
Aggiungi un commento
3 Risposte
Make sure there are batteries in the camera and they work.
Nikon Coolpix p7700 Troubleshooting
Punteggio 0
1 Commento:
I have this same startup failure. On a clean undamaged P7700 camera in which a fully charged 7.7+voltage battery is loaded has no sign of life. I do not know if the v2.0 upgrade has been loaded. Bough this P7700 on ebay reported to be fully operational. Is there a service approach to this problem???
da
Parti e strumenti correlati
Bij het opstarten van de camera krijg ik een witte achtergrond met met txt lensfout.kan ik deze zelf oplossen?
Punteggio 0
I’ve got the same. Any clues?
Seems to be a wide spread issue, there must be some common reason. I hope it’s power board not main at least
Punteggio 0
Aggiungi la tua risposta
Dustin Wahl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 15
Tutti i Tempi: 737
