Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
How can I change the LCD on iPhone 4
How can i change the LCD on iPhone 4
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Like this:
Sostituzione gruppo display iPhone 4
Punteggio 2
1 Commento:
Yes, this is correct. Unfortunately, separating the LCD from the display is quite a task, and doesn't seem to be very doable. You'll have to replace the entire front panel, as shown in the guide.
da
Parti e strumenti correlati
Acquista tutti
Its almost impossible to change out just the lcd of the iPhone 4/4S without damaging the lcd. You have to replace the entire assembly the digitizer and LCD because Apple had fused the LCD to the digitizer for a reason, they made it that way so that dirt, dust,etc. wouldn't get in-between the LCD and Digitizer so they decided to fuse them together as a design change from the previous iPhones the iPhone, iPhone 3G/3GS.
Punteggio 1
Dear Sir
My Iphone do now have an area accross the front tuchscreen where the fingertuch does not work - what to do ?? can I repair it ?
Regards Lion
Punteggio 0
1 Commento:
Replace the front panel, not fixable.
da
Do as showed in the video http://www.youtube.com/watch?v=maC6eHOEB.... if you want the LCD sceen, try to visit
Punteggio 0
you can not only change the LCD separately because LCD and digitizer fused together already,so you must get the iPhone 4 LCD Touch Screen Digitizer Assembly complete kit like this one
Punteggio 0
Aggiungi la tua risposta
fedak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 30,286
