Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
How can I change the LCD on iPhone 4
How can i change the LCD on iPhone 4
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Like this:
Sostituzione gruppo display iPhone 4
Punteggio 2
1 Commento:
Yes, this is correct. Unfortunately, separating the LCD from the display is quite a task, and doesn't seem to be very doable. You'll have to replace the entire front panel, as shown in the guide.
da
Its almost impossible to change out just the lcd of the iPhone 4/4S without damaging the lcd. You have to replace the entire assembly the digitizer and LCD because Apple had fused the LCD to the digitizer for a reason, they made it that way so that dirt, dust,etc. wouldn't get in-between the LCD and Digitizer so they decided to fuse them together as a design change from the previous iPhones the iPhone, iPhone 3G/3GS.
Punteggio 1
Dear Sir
My Iphone do now have an area accross the front tuchscreen where the fingertuch does not work - what to do ?? can I repair it ?
Regards Lion
Punteggio 0
1 Commento:
Replace the front panel, not fixable.
da
Do as showed in the video http://www.youtube.com/watch?v=maC6eHOEB.... if you want the LCD sceen, try to visit
Punteggio 0
you can not only change the LCD separately because LCD and digitizer fused together already,so you must get the iPhone 4 LCD Touch Screen Digitizer Assembly complete kit like this one
Punteggio 0
Aggiungi la tua risposta
fedak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 30,261
