Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F Code on Machine, wont drain
I an getting a F Code, just F no numbers. The clothes are soaked. I unplugged the machine for an hour and it hasn't changed anything. please help me fix this.
Questa è una buona domanda?
Punteggio 8
2 Commenti
My washer had just. Started. It was filling when I got this code. Where is the location of the filters?
da
@christinek94951
What is the model number of the washer?
Did you read the answer below, posted on 22 Nov. 2014 regarding how to check if it is a two part code or not? It may not just be a single "F" code
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
The cold water goes through a mesh screen and often gets clogged. The code usually goes off during the begging of the rinse cycle or at the end. This is when the cold water is most commenly used. YOu have to clean this screen. This is the second time we have had to clean it. The first time with an appliance tech, which cost us close to $100 to do. Now, we will do it ourselves. You just find open up the front, take out the screen when you find it and either clean it with vinegar water or our service tech used muriatic acid.
Punteggio 3
Parti e strumenti popolari
Did you try pushing/holding the pause/cancel button and then pushing the drain cycle setting button? That is what I did and the washer drained and completed the cycle. The clothes are fine. I don't know what is going to happen next time though.
Punteggio 2
id go with cleaning of the filter ...if the front wont do it >>>>I hear there's one also in the back >>>????
Punteggio 1
Update to previous response, the error code is a little tricky to read it displays the "F " first and then alternatively flashes the second part of the code like "06" which you may mistaken for how many minutes are left. A common code for your issue might be F06 when combining the two parts of the code. A washer stopping just before the high spin cycle could indicate a MCU board issue, bad connection to the board in the top of the machine, bad connectors or even a motor issue. Having the correct code will help narrow down your particular issue.
Punteggio 0
$316.66 to replace drain pump / motor assembly is a bad omen because of the 666.
Sears Kenmore Elite model 42822 purchased new in 2003 cost around $1000.
Chat with Sears is awesome. Here is a link to replace part yourself:
http://www.searspartsdirect.com/repair-g...
Punteggio 0
Aggiungi la tua risposta
Susan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 274
Tutti i Tempi: 65,983
