Salta al contenuto principale
iPhone 16 Plus Screen Replacement
Cosa ti serve
  1. iPhone 16 Plus Screen Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPhone 16 Plus Screen Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPhone 16 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPhone 16 Plus Screen Replacement, Remove the pentalobe screws: passo 4, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Remove the pentalobe screws: passo 4, immagine 2 di 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPhone 16 Plus Screen Replacement, Heat the bottom edge: passo 5, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Heat the bottom edge: passo 5, immagine 2 di 2
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPhone 16 Plus Screen Replacement, Insert an opening pick: passo 6, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: passo 6, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPhone 16 Plus Screen Replacement, Screen information: passo 7, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Screen information: passo 7, immagine 2 di 2
    • As you slice the adhesive securing the screen in the next eight steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
    • Multiple spring contacts around the perimeter of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: passo 8, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: passo 8, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: passo 8, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  9. iPhone 16 Plus Screen Replacement, Heat the right edge: passo 9, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Heat the right edge: passo 9, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  10. iPhone 16 Plus Screen Replacement, Separate the right adhesive: passo 10, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Separate the right adhesive: passo 10, immagine 2 di 2
    • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPhone 16 Plus Screen Replacement, Heat the top edge: passo 11, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Heat the top edge: passo 11, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  12. iPhone 16 Plus Screen Replacement, Separate the top adhesive: passo 12, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Separate the top adhesive: passo 12, immagine 2 di 2
    • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPhone 16 Plus Screen Replacement, Heat the left edge: passo 13, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Heat the left edge: passo 13, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  14. iPhone 16 Plus Screen Replacement, Separate the left adhesive: passo 14, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Separate the left adhesive: passo 14, immagine 2 di 2
    • Don't insert your pick deeper than 3 mm to avoid damaging the screen cables and the spring contacts.
    • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPhone 16 Plus Screen Replacement, Prop up the screen: passo 15, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Prop up the screen: passo 15, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Prop up the screen: passo 15, immagine 3 di 3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPhone 16 Plus Screen Replacement, Remove the cover screws: passo 16, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Remove the cover screws: passo 16, immagine 2 di 2
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPhone 16 Plus Screen Replacement, Remove the screen connector covers: passo 17, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the screen connector covers: passo 17, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the screen connector covers: passo 17, immagine 3 di 3
    • Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
    • Lift the cover out of its slot and remove it.
    • Repeat this process for the screen connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  18. iPhone 16 Plus Screen Replacement, Disconnect the screen: passo 18, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Disconnect the screen: passo 18, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Disconnect the screen: passo 18, immagine 3 di 3
    • Use the tip of a spudger to pry up and disconnect the screen press connector.
    • Repeat this process for the front sensor press connector.
    Chiedi a FixBot
    Aggiungi Commento
  19. iPhone 16 Plus Screen Replacement, Remove the screen: passo 19, immagine 1 di 1
    • Lift the screen off of the frame and remove it.
    • Be careful not to damage any of the spring contacts.
    Chiedi a FixBot
    Aggiungi Commento
  20. iPhone 16 Plus Screen Replacement, Remove the ambient light sensor bracket: passo 20, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the ambient light sensor bracket: passo 20, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the ambient light sensor bracket: passo 20, immagine 3 di 3
    • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
    • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
    Chiedi a FixBot
    Aggiungi Commento
  21. iPhone 16 Plus Screen Replacement, Pry up the ambient light sensor: passo 21, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Pry up the ambient light sensor: passo 21, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Pry up the ambient light sensor: passo 21, immagine 3 di 3
    • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
    • Use an opening pick to pry up the ambient light sensor.
    Chiedi a FixBot
    Aggiungi Commento
  22. iPhone 16 Plus Screen Replacement, Peel up the ambient light sensor cable: passo 22, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Peel up the ambient light sensor cable: passo 22, immagine 2 di 2
    • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving to the opposite corner.
    • If the adhesive doesn't peel up easily, apply more heat.
    Chiedi a FixBot
    Aggiungi Commento
  23. iPhone 16 Plus Screen Replacement, Remove the ambient light sensor: passo 23, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the ambient light sensor: passo 23, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the ambient light sensor: passo 23, immagine 3 di 3
    • Continue slowly sliding the opening pick under the ambient light sensor cable until the cable is free from the screen.
    • Use a pair of tweezers to lift the ambient light sensor off of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  24. iPhone 16 Plus Screen Replacement, Disassembly complete: passo 24, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Some reassembly photos are of the iPhone 16 non‑Plus, which may look slightly different. The procedure is correct.
    Chiedi a FixBot
    Aggiungi Commento
  25. iPhone 16 Plus Screen Replacement, Place the ambient light sensor: passo 25, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Place the ambient light sensor: passo 25, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Place the ambient light sensor: passo 25, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Tesa 61395 Tape
    $2.95
    • Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to press the ambient light sensor into its recess.
    • Lay the ambient light sensor cable down on the back of the screen.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
    Chiedi a FixBot
    Aggiungi Commento
  26. iPhone 16 Plus Screen Replacement, Press the ambient light sensor: passo 26, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Press the ambient light sensor: passo 26, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Press the ambient light sensor: passo 26, immagine 3 di 3
    • Use your finger to press down the ambient light sensor cable.
    Chiedi a FixBot
    Aggiungi Commento
  27. iPhone 16 Plus Screen Replacement, Install the ambient light sensor bracket: passo 27, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Install the ambient light sensor bracket: passo 27, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Install the ambient light sensor bracket: passo 27, immagine 3 di 3
    • Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
    • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
    Chiedi a FixBot
    Aggiungi Commento
  28. iPhone 16 Plus Screen Replacement, Remove the screen adhesive: passo 28, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the screen adhesive: passo 28, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the screen adhesive: passo 28, immagine 3 di 3
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up the phone. Connect the screen, power on the phone, and make sure it works as expected. Power it back down, disconnect the screen, and continue reassembly.
    • The adhesive remaining on the phone's frame can be difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  29. iPhone 16 Plus Screen Replacement: passo 29, immagine 1 di 3 iPhone 16 Plus Screen Replacement: passo 29, immagine 2 di 3 iPhone 16 Plus Screen Replacement: passo 29, immagine 3 di 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Chiedi a FixBot
    Aggiungi Commento
  30. iPhone 16 Plus Screen Replacement, Orient the adhesive: passo 30, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Orient the adhesive: passo 30, immagine 2 di 2
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Chiedi a FixBot
    Aggiungi Commento
  31. iPhone 16 Plus Screen Replacement, Expose the bottom edge of the adhesive: passo 31, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Expose the bottom edge of the adhesive: passo 31, immagine 2 di 2
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    Chiedi a FixBot
    Aggiungi Commento
  32. iPhone 16 Plus Screen Replacement, Apply the adhesive: passo 32, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Apply the adhesive: passo 32, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Apply the adhesive: passo 32, immagine 3 di 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  33. iPhone 16 Plus Screen Replacement: passo 33, immagine 1 di 3 iPhone 16 Plus Screen Replacement: passo 33, immagine 2 di 3 iPhone 16 Plus Screen Replacement: passo 33, immagine 3 di 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  34. iPhone 16 Plus Screen Replacement, Press the adhesive into place: passo 34, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Press the adhesive into place: passo 34, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Press the adhesive into place: passo 34, immagine 3 di 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Chiedi a FixBot
    Aggiungi Commento
  35. iPhone 16 Plus Screen Replacement, Remove the top liner: passo 35, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the top liner: passo 35, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the top liner: passo 35, immagine 3 di 3
    • Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
    • Peel back the top liner and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  36. iPhone 16 Plus Screen Replacement: passo 36, immagine 1 di 2 iPhone 16 Plus Screen Replacement: passo 36, immagine 2 di 2
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
    Chiedi a FixBot
    Aggiungi Commento
  37. iPhone 16 Plus Screen Replacement, Prop up the screen: passo 37, immagine 1 di 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Chiedi a FixBot
    Aggiungi Commento
  38. iPhone 16 Plus Screen Replacement, Connect the screen and front sensor: passo 38, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Connect the screen and front sensor: passo 38, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Connect the screen and front sensor: passo 38, immagine 3 di 3
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
    Chiedi a FixBot
    Aggiungi Commento
  39. iPhone 16 Plus Screen Replacement, Cover the connectors: passo 39, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Cover the connectors: passo 39, immagine 2 di 2
    • Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
    Chiedi a FixBot
    Aggiungi Commento
  40. iPhone 16 Plus Screen Replacement: passo 40, immagine 1 di 2 iPhone 16 Plus Screen Replacement: passo 40, immagine 2 di 2
    • Use a pair of tweezers or your fingers to place the front sensor connector cover over the front sensor connector by inserting it at a 90‑degree angle to engage the hook, then laying the cover flat over the connector.
    Chiedi a FixBot
    Aggiungi Commento
  41. iPhone 16 Plus Screen Replacement, Install the cover screws: passo 41, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Install the cover screws: passo 41, immagine 2 di 2
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Chiedi a FixBot
    Aggiungi Commento
  42. iPhone 16 Plus Screen Replacement, Remove the final adhesive liners: passo 42, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Remove the final adhesive liners: passo 42, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Remove the final adhesive liners: passo 42, immagine 3 di 3
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
    Chiedi a FixBot
    Aggiungi Commento
  43. iPhone 16 Plus Screen Replacement: passo 43, immagine 1 di 3 iPhone 16 Plus Screen Replacement: passo 43, immagine 2 di 3 iPhone 16 Plus Screen Replacement: passo 43, immagine 3 di 3
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  44. iPhone 16 Plus Screen Replacement, Place the screen: passo 44, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Place the screen: passo 44, immagine 2 di 2
    • Align the screen over the frame, then lower it into place.
    Chiedi a FixBot
    Aggiungi Commento
  45. iPhone 16 Plus Screen Replacement: passo 45, immagine 1 di 2 iPhone 16 Plus Screen Replacement: passo 45, immagine 2 di 2
    • Firmly press the top edge of the screen into the adhesive, then the bottom edge, until the screen is fully seated in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  46. iPhone 16 Plus Screen Replacement, Heat the screen: passo 46, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Heat the screen: passo 46, immagine 2 di 2
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the screen.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    Chiedi a FixBot
    Aggiungi Commento
  47. iPhone 16 Plus Screen Replacement, Press the back glass: passo 47, immagine 1 di 3 iPhone 16 Plus Screen Replacement, Press the back glass: passo 47, immagine 2 di 3 iPhone 16 Plus Screen Replacement, Press the back glass: passo 47, immagine 3 di 3
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Chiedi a FixBot
    Aggiungi Commento
  48. iPhone 16 Plus Screen Replacement: passo 48, immagine 1 di 2 iPhone 16 Plus Screen Replacement: passo 48, immagine 2 di 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Chiedi a FixBot
    Aggiungi Commento
  49. iPhone 16 Plus Screen Replacement: passo 49, immagine 1 di 3 iPhone 16 Plus Screen Replacement: passo 49, immagine 2 di 3 iPhone 16 Plus Screen Replacement: passo 49, immagine 3 di 3
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Chiedi a FixBot
    Aggiungi Commento
  50. iPhone 16 Plus Screen Replacement: passo 50, immagine 1 di 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Chiedi a FixBot
    Aggiungi Commento
  51. iPhone 16 Plus Screen Replacement, Install the pentalobe screws: passo 51, immagine 1 di 2 iPhone 16 Plus Screen Replacement, Install the pentalobe screws: passo 51, immagine 2 di 2
    • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Plus Answers Community for help.
Altre 2 persone hanno completato questa guida.
Nick Schultz
Membro da: 03/24/24
58.713 Reputazione
318 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
32.107 guide realizzate
1Commento della guida
Wow, have you worked with Apple!
Nabilah Almutairi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 34
Ultimi 7 giorni: 226
Ultimi 30 giorni: 974
Tutti i Tempi: 11,177
