Salta al contenuto principale
iPad 9 LTE Logic Board Replacement
Cosa ti serve
  1. iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: passo 1, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: passo 1, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: passo 1, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. iPad 9 LTE Logic Board Replacement, Heat the left edge: passo 2, immagine 1 di 1
    • Power down your iPad before beginning the repair.
    • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
  3. iPad 9 LTE Logic Board Replacement, Screen removal information: passo 3, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Screen removal information: passo 3, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Screen removal information: passo 3, immagine 3 di 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Ambient light sensors
    • Antennas
    • Display cables
  4. iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: passo 4, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: passo 4, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  5. iPad 9 LTE Logic Board Replacement: passo 5, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 5, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 5, immagine 3 di 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPad 9 LTE Logic Board Replacement: passo 6, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 6, immagine 2 di 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  7. iPad 9 LTE Logic Board Replacement, Insert an opening pick: passo 7, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Insert an opening pick: passo 7, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Insert an opening pick: passo 7, immagine 3 di 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  8. iPad 9 LTE Logic Board Replacement, Separate the left adhesive: passo 8, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the left adhesive: passo 8, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the left adhesive: passo 8, immagine 3 di 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the iPad to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  9. iPad 9 LTE Logic Board Replacement: passo 9, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 9, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 9, immagine 3 di 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  10. iPad 9 LTE Logic Board Replacement: passo 10, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 10, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 10, immagine 3 di 3
    • Slide the first opening pick towards to top-left corner of the iPad to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  11. iPad 9 LTE Logic Board Replacement, Heat the top edge: passo 11, immagine 1 di 1
    • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
  12. iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: passo 12, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: passo 12, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: passo 12, immagine 3 di 3
    • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
    • Only insert the pick up to 7 mm to avoid damaging the ambient light sensor.
  13. iPad 9 LTE Logic Board Replacement, Separate the top adhesive: passo 13, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the top adhesive: passo 13, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the top adhesive: passo 13, immagine 3 di 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  14. iPad 9 LTE Logic Board Replacement: passo 14, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 14, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 14, immagine 3 di 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  15. iPad 9 LTE Logic Board Replacement: passo 15, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 15, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 15, immagine 3 di 3
    • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  16. iPad 9 LTE Logic Board Replacement, Heat the right edge: passo 16, immagine 1 di 1
    • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
  17. iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: passo 17, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: passo 17, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: passo 17, immagine 3 di 3
    • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
    • Only insert the pick up to 4 mm to avoid damaging the ambient light sensor.
  18. iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 18, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 18, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 18, immagine 3 di 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  19. iPad 9 LTE Logic Board Replacement, Heat the bottom edge: passo 19, immagine 1 di 1
    • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
  20. iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: passo 20, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: passo 20, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: passo 20, immagine 3 di 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • The third image shows the bottom-left antenna underneath the digitizer.
    • Leave the pick in the corner before moving to the next step.
  21. iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: passo 21, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: passo 21, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: passo 21, immagine 3 di 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  22. iPad 9 LTE Logic Board Replacement: passo 22, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 22, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 22, immagine 3 di 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
  23. iPad 9 LTE Logic Board Replacement: passo 23, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 23, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 23, immagine 3 di 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  24. iPad 9 LTE Logic Board Replacement, Heat the right edge: passo 24, immagine 1 di 1
  25. iPad 9 LTE Logic Board Replacement: passo 25, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 25, immagine 2 di 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  26. iPad 9 LTE Logic Board Replacement: passo 26, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 26, immagine 2 di 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  27. iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 27, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 27, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: passo 27, immagine 3 di 3
  28. iPad 9 LTE Logic Board Replacement: passo 28, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 28, immagine 2 di 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  29. iPad 9 LTE Logic Board Replacement, Remove the LCD: passo 29, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the LCD: passo 29, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the LCD: passo 29, immagine 3 di 3
    • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
  30. iPad 9 LTE Logic Board Replacement, Unfasten the LCD screen: passo 30, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Unfasten the LCD screen: passo 30, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 4.2 mm screws securing the LCD screen.
  31. iPad 9 LTE Logic Board Replacement, Separate the LCD's adhesive: passo 31, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Separate the LCD's adhesive: passo 31, immagine 2 di 2
    • The LCD is lightly adhered to the frame.
    • Insert a spudger between the frame and the top-right portion of the LCD.
    • Pry slowly with the spudger to separate the adhesive.
  32. iPad 9 LTE Logic Board Replacement: passo 32, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 32, immagine 2 di 2
    • Repeat the previous step for the top-left portion of the LCD.
  33. iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: passo 33, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: passo 33, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: passo 33, immagine 3 di 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
  34. iPad 9 LTE Logic Board Replacement, Disconnect the battery: passo 34, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the battery: passo 34, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  35. iPad 9 LTE Logic Board Replacement, Battery connector information: passo 35, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Battery connector information: passo 35, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Battery connector information: passo 35, immagine 3 di 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  36. iPad 9 LTE Logic Board Replacement, Disconnect the battery: passo 36, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the battery: passo 36, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the battery: passo 36, immagine 3 di 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  37. iPad 9 LTE Logic Board Replacement, Unfasten the display cable bracket: passo 37, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Unfasten the display cable bracket: passo 37, immagine 2 di 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  38. iPad 9 LTE Logic Board Replacement, Remove the display cable bracket: passo 38, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the display cable bracket: passo 38, immagine 2 di 2
    • Remove the display cable bracket.
  39. iPad 9 LTE Logic Board Replacement, Disconnect the LCD: passo 39, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the LCD: passo 39, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  40. iPad 9 LTE Logic Board Replacement, Remove the LCD: passo 40, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the LCD: passo 40, immagine 2 di 2
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  41. iPad 9 LTE Logic Board Replacement, Disconnect the home button: passo 41, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the home button: passo 41, immagine 2 di 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  42. iPad 9 LTE Logic Board Replacement: passo 42, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 42, immagine 2 di 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  43. iPad 9 LTE Logic Board Replacement: passo 43, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 43, immagine 2 di 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  44. iPad 9 LTE Logic Board Replacement, Disconnect the display cables: passo 44, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the display cables: passo 44, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the display cables: passo 44, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  45. iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 45, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 45, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 45, immagine 3 di 3
    • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the buffer block.
  46. iPad 9 LTE Logic Board Replacement: passo 46, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 46, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 46, immagine 3 di 3
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
  47. iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: passo 47, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: passo 47, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: passo 47, immagine 3 di 3
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  48. iPad 9 LTE Logic Board Replacement, Remove the upper bracket tape: passo 48, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the upper bracket tape: passo 48, immagine 2 di 2
    • Carefully peel the LCD buffer tape from the upper component bracket.
  49. iPad 9 LTE Logic Board Replacement, Unfasten the upper component bracket: passo 49, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Unfasten the upper component bracket: passo 49, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the five screws securing the the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  50. iPad 9 LTE Logic Board Replacement, Remove the upper component bracket: passo 50, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the upper component bracket: passo 50, immagine 2 di 2
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
  51. iPad 9 LTE Logic Board Replacement: passo 51, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 51, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 51, immagine 3 di 3
    • Use your fingers to peel the upper component bracket away from the tape.
    • Remove the upper component bracket.
  52. iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: passo 52, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: passo 52, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: passo 52, immagine 3 di 3
    • Peel off any tape covering the left ambient light sensor's ZIF connector.
  53. iPad 9 LTE Logic Board Replacement: passo 53, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 53, immagine 2 di 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the left ambient light sensor's ZIF connector.
  54. iPad 9 LTE Logic Board Replacement: passo 54, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 54, immagine 2 di 2
    • Use a pair of tweezers to carefully pull the left ambient light sensor cable straight out of the ZIF connector.
  55. iPad 9 LTE Logic Board Replacement, Remove the left ambient light sensor: passo 55, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the left ambient light sensor: passo 55, immagine 2 di 2
    • The left ambient light sensor is lightly adhered to the frame.
    • Use tweezers, or your fingers, to remove the sensor from the frame.
  56. iPad 9 LTE Logic Board Replacement: passo 56, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 56, immagine 2 di 2
    • Use tweezers to remove any adhesive remaining on the frame.
  57. iPad 9 LTE Logic Board Replacement, Disconnect the headphone jack: passo 57, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the headphone jack: passo 57, immagine 2 di 2
    • Peel back any tape covering the headphone jack's press connector.
  58. iPad 9 LTE Logic Board Replacement: passo 58, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 58, immagine 2 di 2
    • Use the flat end of the spudger to pry up and disconnect the headphone jack's press connector.
  59. iPad 9 LTE Logic Board Replacement: passo 59, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 59, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 59, immagine 3 di 3
    • The headphone jack cable is lightly adhered to the frame.
    • Use tweezers, or your fingers, to peel the headphone jack cable up from the frame.
  60. iPad 9 LTE Logic Board Replacement, Unfasten the headphone jack: passo 60, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Unfasten the headphone jack: passo 60, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 3.3 mm-long screw securing the headphone jack from the frame.
  61. iPad 9 LTE Logic Board Replacement, Remove the headphone jack: passo 61, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the headphone jack: passo 61, immagine 2 di 2
    • Use a pair of tweezers to pull the headphone jack out of its enclosure and remove it.
  62. iPad 9 LTE Logic Board Replacement, Disconnect the front camera: passo 62, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the front camera: passo 62, immagine 2 di 2
    • Peel off any tape covering the front camera's ZIF connector.
  63. iPad 9 LTE Logic Board Replacement: passo 63, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 63, immagine 2 di 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the front camera's ZIF connector.
  64. iPad 9 LTE Logic Board Replacement: passo 64, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 64, immagine 2 di 2
    • Use a pair of tweezers to carefully pull the front camera cable straight out of the ZIF connector.
  65. iPad 9 LTE Logic Board Replacement, Heat the front camera: passo 65, immagine 1 di 1
    • Apply a heated iOpener to the top of the iPad for 90 seconds.
  66. iPad 9 LTE Logic Board Replacement, Remove the front camera: passo 66, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the front camera: passo 66, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the front camera: passo 66, immagine 3 di 3
    • Insert the flat end of a spudger between the front camera and the frame.
    • Gently pry up to separate the adhesive.
    • If you're having difficulty separating the adhesive, apply more heat and pry at different angles.
    • Use tweezers to remove the front camera from its recess.
  67. iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: passo 67, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: passo 67, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: passo 67, immagine 3 di 3
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the cellular antennas to the rear case.
  68. iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: passo 68, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: passo 68, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: passo 68, immagine 3 di 3
    • Use the pointed end of a spudger to disconnect the right cellular antenna coaxial cable by prying up as close to the connector as possible.
    • Repeat the procedure to disconnect the left antenna cable.
  69. iPad 9 LTE Logic Board Replacement: passo 69, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 69, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 69, immagine 3 di 3
    • Peel the left cellular antenna coaxial cable away from the rear case.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  70. iPad 9 LTE Logic Board Replacement: passo 70, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 70, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 70, immagine 3 di 3
    • Use a spudger to pry up and disconnect both cellular antennas' press connectors secured to the logic board.
  71. iPad 9 LTE Logic Board Replacement, Disconnect the rear camera: passo 71, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the rear camera: passo 71, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
  72. iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: passo 72, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: passo 72, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: passo 72, immagine 3 di 3
    • Peel off any tape covering the button control cable ZIF connector.
  73. iPad 9 LTE Logic Board Replacement: passo 73, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 73, immagine 2 di 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  74. iPad 9 LTE Logic Board Replacement: passo 74, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 74, immagine 2 di 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
  75. iPad 9 LTE Logic Board Replacement, Disconnect the Smart Cover sensor: passo 75, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the Smart Cover sensor: passo 75, immagine 2 di 2
    • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
  76. iPad 9 LTE Logic Board Replacement: passo 76, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 76, immagine 2 di 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
  77. iPad 9 LTE Logic Board Replacement: passo 77, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 77, immagine 2 di 2
    • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
  78. iPad 9 LTE Logic Board Replacement, Disconnect the SIM card reader: passo 78, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the SIM card reader: passo 78, immagine 2 di 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the SIM card reader cable ZIF connector.
  79. iPad 9 LTE Logic Board Replacement: passo 79, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 79, immagine 2 di 2
    • Use a pair of tweezers to carefully pull the SIM card reader cable straight out of the ZIF connector.
  80. iPad 9 LTE Logic Board Replacement, Disconnect the antennas: passo 80, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the antennas: passo 80, immagine 2 di 2
    • Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
  81. iPad 9 LTE Logic Board Replacement: passo 81, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 81, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 81, immagine 3 di 3
    • Peel up the right antenna cable.
  82. iPad 9 LTE Logic Board Replacement, Disconnect the left antenna: passo 82, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the left antenna: passo 82, immagine 2 di 2
    • Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
  83. iPad 9 LTE Logic Board Replacement: passo 83, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 83, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 83, immagine 3 di 3
    • Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
  84. iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 84, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 84, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: passo 84, immagine 3 di 3
    • Use the flat end of a spudger to pry up the buffer block at the bottom left corner of the iPad.
    • Use a pair of tweezers to remove the buffer block.
  85. iPad 9 LTE Logic Board Replacement, Disconnect the speakers: passo 85, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the speakers: passo 85, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Disconnect the speakers: passo 85, immagine 3 di 3
    • Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
  86. iPad 9 LTE Logic Board Replacement: passo 86, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 86, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 86, immagine 3 di 3
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
  87. iPad 9 LTE Logic Board Replacement: passo 87, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 87, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 87, immagine 3 di 3
    • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
  88. iPad 9 LTE Logic Board Replacement, Disconnect the Smart Connector: passo 88, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the Smart Connector: passo 88, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
  89. iPad 9 LTE Logic Board Replacement: passo 89, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 89, immagine 2 di 2
    • Use a pair of tweezers to disconnect the Smart Connector cable connector by lifting straight up.
  90. iPad 9 LTE Logic Board Replacement: passo 90, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 90, immagine 2 di 2
    • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the rear case.
  91. iPad 9 LTE Logic Board Replacement: passo 91, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 91, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 91, immagine 3 di 3
    • Peel the Smart Connector cables away from the rear case.
  92. iPad 9 LTE Logic Board Replacement, Heat the SIM card reader: passo 92, immagine 1 di 1
    • Apply a heated iOpener to the bottom left corner of the rear case for one minute to loosen the SIM card reader's adhesive.
  93. iPad 9 LTE Logic Board Replacement, Remove the SIM card reader: passo 93, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Remove the SIM card reader: passo 93, immagine 2 di 2
    • Be sure you've ejected the SIM card tray before continuing.
    • Use an opening tool to pry up on the bottom edge of the SIM card reader with a slow and steady force.
    • If the SIM card reader feels extra stuck, apply more heat and try again.
  94. iPad 9 LTE Logic Board Replacement: passo 94, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 94, immagine 2 di 2
    • Remove the SIM card reader.
  95. iPad 9 LTE Logic Board Replacement, Disconnect the charging port: passo 95, immagine 1 di 2 iPad 9 LTE Logic Board Replacement, Disconnect the charging port: passo 95, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
    • Two 2.2 mm-long screws
    • Two 3.2 mm-long screws
  96. iPad 9 LTE Logic Board Replacement, Heat the logic board: passo 96, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Heat the logic board: passo 96, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Heat the logic board: passo 96, immagine 3 di 3
    • Apply a heated iOpener to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
  97. iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: passo 97, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: passo 97, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: passo 97, immagine 3 di 3
    • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
  98. iPad 9 LTE Logic Board Replacement: passo 98, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 98, immagine 2 di 2
    • Pull the charging port out of its slot in the rear case.
  99. iPad 9 LTE Logic Board Replacement, Remove the logic board: passo 99, immagine 1 di 3 iPad 9 LTE Logic Board Replacement, Remove the logic board: passo 99, immagine 2 di 3 iPad 9 LTE Logic Board Replacement, Remove the logic board: passo 99, immagine 3 di 3
    • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the rear case.
    • Leave the opening pick inserted to keep the adhesive from re-adhering.
  100. iPad 9 LTE Logic Board Replacement: passo 100, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 100, immagine 2 di 2
    • Remove the battery blocker.
  101. iPad 9 LTE Logic Board Replacement: passo 101, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 101, immagine 2 di 2
    • Insert an opening tool near the bottom of the logic board and pry up with a slow and steady force to peel it away from the rear case.
    • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
    • Slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive if your logic board won't budge.
  102. iPad 9 LTE Logic Board Replacement: passo 102, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 102, immagine 2 di 2
    • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the rear case.
  103. iPad 9 LTE Logic Board Replacement: passo 103, immagine 1 di 2 iPad 9 LTE Logic Board Replacement: passo 103, immagine 2 di 2
    • Insert an opening tool near the top of the logic board and pry up with a slow and steady force to peel it away from the rear case.
  104. iPad 9 LTE Logic Board Replacement: passo 104, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 104, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 104, immagine 3 di 3
    • Insert an opening tool near the middle of the logic board and pry up until you can grip it with your fingers.
  105. iPad 9 LTE Logic Board Replacement: passo 105, immagine 1 di 3 iPad 9 LTE Logic Board Replacement: passo 105, immagine 2 di 3 iPad 9 LTE Logic Board Replacement: passo 105, immagine 3 di 3
    Halberd Spudger
    $2.99
    • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the rear case.
  106. iPad 9 LTE Logic Board Replacement: passo 106, immagine 1 di 1
    Tesa 61395 Tape
    $5.99
    • Remove the logic board.
    • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
    • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
Altre 2 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
212.632 Reputazione
1.039 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,805
