Salta al contenuto principale
WowWee MiP Robot Tire Replacement
Moira Keahon
Moira Keahon e 8 altri collaboratori
Ultimo aggiornamento il December 19, 2023
15 - 20 minuti
Facile
Introduzione
Vai al passo 1
This guide is designed to help users remove MiP’s wheels. MiP has two wheels that are connected to its body with screws. If the wheels need replacement or cleaning, follow this guide.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. WowWee MiP Robot Tire Replacement, Wheel: passo 1, immagine 1 di 2 WowWee MiP Robot Tire Replacement, Wheel: passo 1, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - Replica
  2. WowWee MiP Robot Tire Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Tire Replacement: passo 2, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: passo 3, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: passo 4, immagine 1 di 2 WowWee MiP Robot Tire Replacement, Tires: passo 4, immagine 2 di 2
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: passo 5, immagine 1 di 3 WowWee MiP Robot Tire Replacement: passo 5, immagine 2 di 3 WowWee MiP Robot Tire Replacement: passo 5, immagine 3 di 3
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
my MiP has plastic over his wheels
Clarrie O'HARE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 27
Tutti i Tempi: 6,287
