Salta al contenuto principale
WowWee MiP Robot Tire Replacement
Cosa ti serve
  1. WowWee MiP Robot Tire Replacement, Wheel: passo 1, immagine 1 di 2 WowWee MiP Robot Tire Replacement, Wheel: passo 1, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - Replica
  2. WowWee MiP Robot Tire Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Tire Replacement: passo 2, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: passo 3, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: passo 4, immagine 1 di 2 WowWee MiP Robot Tire Replacement, Tires: passo 4, immagine 2 di 2
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: passo 5, immagine 1 di 3 WowWee MiP Robot Tire Replacement: passo 5, immagine 2 di 3 WowWee MiP Robot Tire Replacement: passo 5, immagine 3 di 3
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
my MiP has plastic over his wheels
Clarrie O'HARE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,277
