Salta al contenuto principale
Wahl Lithium Ion Trimmer  Slide switch Replacement
nathan
nathan e 3 altri collaboratori
Ultimo aggiornamento il January 21, 2025
Nessuna stima
Moderato
Vigilanza sulla Grammatica
Pallini!
Testo Confuso
Necessarie Immagini Migliori
Prerequisite Mancanti
Introduzione
Vai al passo 1
This guide will teach you how to replace the power switch on your razor instead of going and buying a new razor all together. This switch has a plastic mechanism that is connected to the slider from the inside. The plastic switch is in between the battery and motor that controls power. This switch could get jammed or broken off.
  1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: passo 1, immagine 1 di 1
    • Start at the last step of the disassembly guide.
  2. Wahl Lithium Ion Trimmer  Slide switch Replacement: passo 2, immagine 1 di 1
    • remove the inside on the razor which includes the chip set, battery, motor and switch.
  3. Wahl Lithium Ion Trimmer  Slide switch Replacement: passo 3, immagine 1 di 1
    • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
  4. Wahl Lithium Ion Trimmer  Slide switch Replacement: passo 4, immagine 1 di 1
    • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
  5. Wahl Lithium Ion Trimmer  Slide switch Replacement: passo 5, immagine 1 di 1
    • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
Conclusione
1Commento della guida
Where can you source this part from?
John - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,442
