Salta al contenuto principale
Sony RM-LVR1 LCD Screen Replacement
Alexander Thomas
Alexander Thomas e 5 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will teach you step by step how to replace your LCD screen.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony RM-LVR1 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 LCD Screen Replacement, LCD Screen: passo 3, immagine 1 di 2 Sony RM-LVR1 LCD Screen Replacement, LCD Screen: passo 3, immagine 2 di 2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 LCD Screen Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
    Salut, svp referance de l'LCD?
    be_vdp - Replica
  7. Sony RM-LVR1 LCD Screen Replacement: passo 7, immagine 1 di 2 Sony RM-LVR1 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the screen from the motherboard.
Conclusione
4Commenti sulla guida
здорово!
подскажите где купить дисплей?, или его маркировку?. на дисплее ничего не написано, не могу найти.
Александр - Replica
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
Sven van Bellen - Replica
any link to the replacement LCD please?
Bart Ptachowski - Replica
Hi .
search : HD 170 LCD Drift aliexp****
i think it will do the job .
cheers
ruigyl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 585
