Samsung Galaxy Note 3 Battery Replacement
Introduzione
Vai al passo 1Follow the steps in order to replace your battery.
If your battery is swollen, take appropriate precautions.
Cosa ti serve
Ricambi
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Altre 46 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
