Salta al contenuto principale
Repairing Quasar Microwave Sparking Inside
Michael
Michael e 8 altri collaboratori
Ultimo aggiornamento il September 3, 2019
10 - 15 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
The Quasar MQ7774XW microwave was introduced in 1984. This replacement repair guide shows the necessary steps that must be taken if sparking occurs on the inside of the microwave.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Repairing Quasar Microwave Sparking Inside, Disassembling Quasar Microwave Outer Cover: passo 1, immagine 1 di 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Sparking Inside: passo 2, immagine 1 di 2 Repairing Quasar Microwave Sparking Inside: passo 2, immagine 2 di 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Sparking Inside: passo 3, immagine 1 di 2 Repairing Quasar Microwave Sparking Inside: passo 3, immagine 2 di 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Sparking Inside: passo 4, immagine 1 di 3 Repairing Quasar Microwave Sparking Inside: passo 4, immagine 2 di 3 Repairing Quasar Microwave Sparking Inside: passo 4, immagine 3 di 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
    How to replace the Fuse
    Fred Schlaich - Replica
  5. Repairing Quasar Microwave Sparking Inside, Sparking: passo 5, immagine 1 di 1
    • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
    • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
  6. Repairing Quasar Microwave Sparking Inside: passo 6, immagine 1 di 1
    • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
    • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
  7. Repairing Quasar Microwave Sparking Inside: passo 7, immagine 1 di 1
    • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
    • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
    The diagnosis for a sparking Microwave, can never be a faulty HV Diode. If the diode was faulty there not be enough power to feed the magnetron.
    Sparking inside a microwave is normally by 1 of 3 reasons: 1. metal objects inside the cavity when it is switched on and power injected into the cavity can not be sufficiently absorbed by the load (Food), 2. this could be caused by metal objects inside the cavity, which reflect the injected power back to the magnetron. or 3. it can be caused by a dirty or contaminated waveguide cover. If this is not checked urgently, the antenna of the magnetron can be damaged and may even implode, and this could be very, very violent, possibly causing building damage.
    A mis-aligned magnetron will not cause sparking. It will cause leakages of very high frequency microwaves, which can cause gangrene and possible loss of limbs. This is dangerous.
    Jan - Replica
    To test your HV Diode, you can not use your multimeter on the resistance setting on "diode test"mode, It will not work. You need to have a multimeter that has a resistance setting for 200M ohm or higher. Measuring one way will give a zero, or very low ohms reading. Reversing the leads will give a higher ohms reading.
    Just a side note: there is usually a note on the microwave stating that it should only be serviced by a qualified person. It is there for a reason as there are voltages up to 2500V floating around there. I will seriously hurt you, or even possibly kill you. Ever felt a capacitor discharge at that voltage? I promise you it is something you will never forget. I would also recommend that you get serious about posting these tips before you have consulted with a qualified person. I just felt I had to post this before someone gets hurt!!
    Jan - Replica
Conclusione
Altre 7 persone hanno completato questa guida.
Michael
Membro da: 09/26/12
237 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
1Commento della guida
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
Eric Ouyang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,522
