Salta al contenuto principale
Petcube Play 2 Speaker Replacement
Jim Clifton
Jim Clifton e 3 altri collaboratori
Ultimo aggiornamento il June 29, 2024
30 minuti - 1 ora
Difficile
Introduzione
Vai al passo 1
If the speaker of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
A defective speaker might lead to distorted sound output or no output at all.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection related issues and how to address them.
In step 4 of this guide, you will need to remove the soldering from wires to detach the speaker. Be sure to carefully follow the IFixit soldering instructions to avoid burning yourself or damaging the device. Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Cosa ti serve
Strumenti
Mostra di più…
  1. Petcube Play 2 Speaker Replacement, Motherboard: passo 1, immagine 1 di 3 Petcube Play 2 Speaker Replacement, Motherboard: passo 1, immagine 2 di 3 Petcube Play 2 Speaker Replacement, Motherboard: passo 1, immagine 3 di 3
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 Speaker Replacement: passo 2, immagine 1 di 2 Petcube Play 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the four 3.5mm screws from under the rubber cover with a Phillips #1 screwdriver.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Speaker Replacement: passo 3, immagine 1 di 2 Petcube Play 2 Speaker Replacement: passo 3, immagine 2 di 2
    • Carefully pry off the glass front panel with an opening pick or spudger.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Speaker Replacement: passo 4, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 4, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 4, immagine 3 di 3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Speaker Replacement: passo 5, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 5, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 5, immagine 3 di 3
    • Once the internal assembly is removed, a brass cylinder in a corner of the front face of the cube should be visible. Connected to the cylinder is a screw.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 Speaker Replacement: passo 6, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 6, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 6, immagine 3 di 3
    • Flip the cube onto its side to locate the pull tab(s).
    • Flip the cube onto its side to locate the pull tab(s). Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Speaker Replacement: passo 7, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 7, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 7, immagine 3 di 3
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Speaker Replacement: passo 8, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 8, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 8, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs located on the sides of the cube and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 Speaker Replacement, Speaker: passo 9, immagine 1 di 3 Petcube Play 2 Speaker Replacement, Speaker: passo 9, immagine 2 di 3 Petcube Play 2 Speaker Replacement, Speaker: passo 9, immagine 3 di 3
    • Take the half of the device that doesn't contain the motherboard and place it down so that the top screws are visible.
    • Use a Phillips #1 screwdriver to remove the seven screws.
  10. Petcube Play 2 Speaker Replacement: passo 10, immagine 1 di 1
    • Use tweezers to remove the wire connector attaching the two halves together.
    • Separate the two halves and isolate the one containing the speaker.
  11. Petcube Play 2 Speaker Replacement: passo 11, immagine 1 di 2 Petcube Play 2 Speaker Replacement: passo 11, immagine 2 di 2
    • On the other half of the cube, remove the four screws using a Phillips #1 screwdriver.
  12. Petcube Play 2 Speaker Replacement: passo 12, immagine 1 di 2 Petcube Play 2 Speaker Replacement: passo 12, immagine 2 di 2
    • Grip the flat bottom and the cover of the speaker and gently pull them apart to separate to expose the speaker.
    • Be careful when pulling the two apart to avoid damaging the other internal parts as they are connected by the speaker cable.
  13. Petcube Play 2 Speaker Replacement: passo 13, immagine 1 di 3 Petcube Play 2 Speaker Replacement: passo 13, immagine 2 di 3 Petcube Play 2 Speaker Replacement: passo 13, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the speaker.
    • Use a soldering iron to desolder the wires connecting the speaker to the device.
    • Make sure to follow safety protocols with soldering and take your time as to prevent injury.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jim Clifton
Membro da: 03/18/24
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 78
