Salta al contenuto principale
Petcube Play 2 LED Replacement
Christopher Pereira
Christopher Pereira e 5 altri collaboratori
Ultimo aggiornamento il January 10, 2025
45 minuti - 1 ora
Difficile
Foto Azione
Necessarie Più Immagini
Introduzione
Vai al passo 1
If the microphone of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with an LED that turns different colors that relay what state the Petcube is in. These can include when the LED turning green when setting up, turning blue when it is streaming, and error-related colors like orange when there is no access point. A defective LED will not turn on.
Before using this guide, ensure that there are no other issues with the LED. The Troubleshooting Page covers issues that could be preventing the LED from turning on and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process. This guide requires soldering. For more information on soldering, take a look at this guide on How to Solder and Desolder Connections.
Cosa ti serve
Strumenti
Mostra di più…
  1. Petcube Play 2 LED Replacement, Motherboard: passo 1, immagine 1 di 3 Petcube Play 2 LED Replacement, Motherboard: passo 1, immagine 2 di 3 Petcube Play 2 LED Replacement, Motherboard: passo 1, immagine 3 di 3
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 LED Replacement: passo 2, immagine 1 di 2 Petcube Play 2 LED Replacement: passo 2, immagine 2 di 2
    • Remove the four 3.5mm screws from under the rubber cover with a Phillips #1 screwdriver.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 LED Replacement: passo 3, immagine 1 di 2 Petcube Play 2 LED Replacement: passo 3, immagine 2 di 2
    • Carefully pry off the glass front panel with an opening pick or spudger.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 LED Replacement: passo 4, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 4, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 4, immagine 3 di 3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 LED Replacement: passo 5, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 5, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 5, immagine 3 di 3
    • Once the internal assembly is removed, a brass cylinder in a corner of the front face of the cube should be visible. Connected to the cylinder is a screw.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 LED Replacement: passo 6, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 6, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 6, immagine 3 di 3
    • Flip the cube onto its side to locate the pull tab(s).
    • Flip the cube onto its side to locate the pull tab(s). Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 LED Replacement: passo 7, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 7, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 7, immagine 3 di 3
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 LED Replacement: passo 8, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 8, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 8, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs located on the sides of the cube and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 LED Replacement, LED: passo 9, immagine 1 di 3 Petcube Play 2 LED Replacement, LED: passo 9, immagine 2 di 3 Petcube Play 2 LED Replacement, LED: passo 9, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the screws to disconnect the front plates from each other.
  10. Petcube Play 2 LED Replacement: passo 10, immagine 1 di 3 Petcube Play 2 LED Replacement: passo 10, immagine 2 di 3 Petcube Play 2 LED Replacement: passo 10, immagine 3 di 3
    • Remove the front plastic casing from the circuit board.
    • Identify the LED and the foam protector.
    • Remove the foam protector by gently pulling upwards with thin tweezers.
    • Use a soldering iron to desolder the LED from the board. Solder the new LED in the same place and orientation.
    • Never touch a hot soldering iron.
    • When soldering, be careful not to damage any other components be resting the iron on them. Remove the solder on the LED only, then solder the new one on.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 130
