Salta al contenuto principale
Nintendo Switch Pro Controller Rumble Modules Replacement
Jean Galindez
Jean Galindez e 6 altri collaboratori
Ultimo aggiornamento il 27 apr 2025
1 ora
Difficile
Introduzione
Vai al passo 1
This guide is used for the replacement of the Rumble Modules on your Nintendo Switch Pro Controller. Take precaution when completing this guide because it involves the removal of a lithium-ion battery. If the battery is swollen, check out this resource on how to dispose of a swollen battery. To complete this guide correctly you must complete steps eight and nine with caution so as to not damage the white ribbon. In addition, you must be able to solder, so if you do not know how to solder, check out this resource on how to solder. Be careful when removing the plastic pieces and the internal circuit board of the controller so as to not damage the components.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Be carefull, these screws are super easy to strip even with the right tools.
    Lukas Eberharter - Replica
    I tried editing these instructions after I had trouble with stripping screws, but it doesn't seem to take. The issue is that these are JIS and not Phillips screws. They are VERY similar looking but a Phillips head screwdriver will strip the screws.
    Isaac Webb - Replica
    I tried using a Philips #00 screwdriver but it didn’t work
    vincent ingrassia - Replica
    Don't even think about trying Phillips. There are some other guides online that say you'll be fine, but they're wrong. Even one attempt with Phillips WILL strip these, and you will never, ever get this controller open once that happens. Even with JIS they're really hard to get out and really easy to strip.
    Luke T. Allen - Replica
  2. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: passo 2, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: passo 2, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: passo 2, immagine 3 di 3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: passo 3, immagine 1 di 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: passo 4, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: passo 4, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: passo 4, immagine 3 di 3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the clear plastic cover: passo 5, immagine 1 di 1
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: passo 6, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: passo 6, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: passo 6, immagine 3 di 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: passo 7, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: passo 7, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: passo 7, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
    the 2 screws up at the top are unreachable with the standard fixit kit just a heads up
    drew - Replica
    Seconded. the screws are located too deep below the plastic slot, and the bit holding bulge is too wide for the small aperture (similarly with the flexible extension). the bit length is too shallow to reach.
    An alternative driver with a much narrower & longer shaft is required, which will likely not come with interchangeable bits.
    Douglas Selby -
    I would say it is possible to reach the top left screw, just not the top right - there is a gap in the top left that allows you to slightly bend the standard driver outward to turn it while still making adequate contact.
    El_Mechacontext - Replica
    An update: I was actually able to remove the top right one in a really hacky way - inserting the Phillips #0 bit into the #4 hex bit, and then using that in the standard driver. This added just enough length to successfully reach and make full contact with the screw!
    El_Mechacontext -
    Using the #4 hex bit as an extension was the exact "hack" I needed to get rid of the drift finally. Thank you. You're a lifesaver.
    Das #4 Hex Bit als Verlängerung für das Kreuzschlitz Bit zu nutzen ist zwar etwas eng, aber es erspart einem wirklich einen zusätzlichen Schraubendreher.
    Techn0magier -
  8. Nintendo Switch Pro Controller Rumble Modules Replacement: passo 8, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement: passo 8, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement: passo 8, immagine 3 di 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    Didn't realize there is adhesive holding the front cover onto the unit. It's located inside of the handles. Just a bit of force there helped, just be careful of the cable.
    Roger Perez - Replica
    this step is really hard
    XDchlapec - Replica
    You can use a pry tool to pry the part of the top shell covering the handles off the adhesive in order to make this step less like pulling teeth.
    Charlie - Replica
  9. Nintendo Switch Pro Controller Rumble Modules Replacement, Open the flap: passo 9, immagine 1 di 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Open the flap: passo 9, immagine 2 di 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    Having just completed this repair, I noted that this ribbon cable can disconnect on either side. It is easier to disconnect and reconnect from the other side than what is shown in my experience.
    acestronautical - Replica
    @acestronautical is right! much easier to remove the ribbon cable from the button board, connect to the base board and then connect back to the button board. Thank you @acestronautical
    Joe Rickerby - Replica
  10. Nintendo Switch Pro Controller Rumble Modules Replacement, Disconnect the interconnect cable: passo 10, immagine 1 di 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Disconnect the interconnect cable: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    You don't need to disconnect this as long as you are fine with keeping it close by so as not to rip the ribbon cable.
    Caden Helm - Replica
  11. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the front case: passo 11, immagine 1 di 1
    • Remove the front case.
  12. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: passo 12, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: passo 12, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: passo 12, immagine 3 di 3
    • With light force pull the two joystick caps off of the controller.
  13. Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: passo 13, immagine 1 di 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: passo 13, immagine 2 di 2
    • Insert the tip of a spudger from the back into the hole on the right controller handle.
    • Push the spudger through the hole to loosen the adhesive which is holding rumble modules in their places.
  14. Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: passo 14, immagine 1 di 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: passo 14, immagine 2 di 2
    • Insert the tip of a spudger from the back into the hole on the left controller handle.
  15. Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the modules: passo 15, immagine 1 di 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the modules: passo 15, immagine 2 di 2
    • Use a pair tweezers to lift the modules out of their places.
  16. Nintendo Switch Pro Controller Rumble Modules Replacement, Unscrew the motherboard: passo 16, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 5 mm-long screws securing the motherboard.
  17. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: passo 17, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: passo 17, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: passo 17, immagine 3 di 3
    • Use your thumb or a pair of tweezers to to take off the white LED light housing.
  18. Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: passo 18, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: passo 18, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: passo 18, immagine 3 di 3
    • Lift the motherboard carefully as to not damage the wires and flip it to reveal the backside.
  19. Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: passo 19, immagine 1 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: passo 19, immagine 2 di 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: passo 19, immagine 3 di 3
    • Desolder the rumble motor solder points on either side of the motherboard.
    • Remove the rumble modules.
    • Refer to the following solder guide if necessary: How to Solder
    • Solder the new rumble modules into the same pins.
Conclusione
2Commenti sulla guida
Is the controller operational if I just leave the rumble module de-soldered?
amp - Replica
It is! Somehow the one motor on the right hand side of mine started heating up and smoking, so I took it out. Left one is still fine, so I still get some rumble, and controller works as normal.
OtherScott - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 74
Ultimi 30 Giorni: 256
Tutti i Tempi: 10,353
