Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement
Introduzione
Vai al passo 1Follow this guide to replace the display assembly, including the display frame. This requires the battery as well as many other components to be removed from the old frame and transferred to the new frame.
Your replacement part should look like this. If your replacement part consists only of the display assembly, you must complete additional steps, which are not covered by this guide.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Insert an opening pick underneath the flat flex cable and slide it to free the cable from the frame.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$5.99
Only the LCD screen and digitizer assembly (with frame) should remain.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
Altre 6 persone hanno completato questa guida.
