Salta al contenuto principale
Microsoft Surface Book Screen Replacement
Cosa ti serve
  1. Microsoft Surface Book Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Heat an iOpener and lay it on the bottom edge of the screen to soften the glue securing it.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat can damage the screen and/or battery.
    Once you insert an opening pick, you can use a few drops of Acetone around the edge to loosen the glue. I found this much easier than keep reheating the iOpener and possibly cracked the display.
    dan89fernando - Replica
    Bad idea to use acetone with these types of devices because of the plastic parts that can become either damaged or outright melted by the solvent. (Especially the ribbon cables and connections) You are better off using isopropyl alcohol or nothing. Easy enough just to avoid this idea completely. Not to mention that it is possible to cause the display to shatter due to thermal shock when you apply the solvent to a heated surface. Good luck to those that try anyway.
    Rick Sanchez - Replica
    The iOpener did nothing to loosen up the glue. Had to use a hair dryer for almost 40 minutes to get it softened up enough to open.
    david alexis - Replica
    Took at least 30 mins with a hair dryer to get the screen off. That 20 min completion time is total BS.
    Tommy - Replica
    my screen is 25% off
    Daniel R Patton - Replica
    Be EXTRA careful when running the opening pick around the bottom right portion of the screen. This is where the touch controller attaches to the display, and the ribbon cable is only about a quarter inch away from the edge and is easy to rip out.
    Alexander V Trofimuk - Replica
    Very important hint!
    Andreas -
    YES! This needs to be called out specifically in the guide. The ribbon is so close to the edge, you will damage it if you are not careful.
    meh -
    Having recently been inside a Surface Book I purchased via Facebook marketplace, consider the screen a “cost” of replacing the battery and the pressure is off of you. I tried VERY hard not to break the glass, but…still happened. With that out of the way, I successfully replaced the screen, battery, and also battery in the base. Microsoft should be ashamed of this device. All that engineering effort built into their crappy hinge, only to have the batteries fail prematurely. Also, the mechanism to release the screen from the base sucks real bad. Mine doesn’t work, I carry a paper clip with me to unleash the tablet mode. Pathetic. Thank GOD I picked this up second hand for a few hundred bucks. Pity the folks that paid two grand or more for this turd.
    Ken Okpych - Replica
    after I did reassemble back the screen, before applying the new tapes I did test it for one day and I did find out the right release mechanism was not working anymore. Accidentally I did disconnect the control wire coming from the main board. Easy to put it back in position. No need to dismantle all again. So, you can give a try and check the connectors. Both the connectors did disconnect while removing the mainboard. Just be careful and check them before gluing all back! Hope it helps.
    Gian Paolo -
    I just tried for over an hour and a half with heat packs and a dyson hair dryer, and got absolutely nowhere… I even bought the iSclack and had ifixit openers at the ready. I guess I’ll try a heat gun next (after I buy one). If anyone has any other suggestions, it would really be appreciated… I’m so disappointed in Microsoft right now.
    Trevor Brown - Replica
    If you use a heat gun make sure to keep it moving along the edge and use your hand to shield the rest of the screen from getting hit with heat. You only want it to be hot to the touch and no further. You take a big risk of discoloring the screen if you overheat a part. Heat gun did make life much easier but you have to be very very careful and concentrated while using it.
    andrew.j.nieto -
    I got my computer open after completely abandoning the “step 1” instructions here. The hot pack (iOPener) and suction cups (iSclack) were completely worthless for me, and did absolutely nothing. Instead, simply get yourself a tool with a very thin metal knife, such as the “Jimmy” sold here on iFixit.
    Use a heat gun to get a section of the screen nice and hot (I went with ~160 degrees Fahrenheit) then insert the Jimmy vertically in between the screen and the metal frame (a tiny gap.) Then, carefully flip it horizontally to get between the tape and the screen. After this, carefully slide the knife along the edge while using a heat gun to hover right over the place the knife will next be (I used gloves to prevent burning my hands.) Do NOT insert the knife more than a half an inch into the gap, or you might damage your screen (stay within the black bezel range.)
    This will QUICKLY, EASILY, and SAFELY get the screen off.
    Attempted to do this without enough heat and the glass shattered; recommend using a heat gun and potentially using repair tape to keep the glass intact. The screen removal is the hardest part of everything.
    J.K. - Replica
    I broke my screen too, but I blame myself for being impatient. Once I took my time heating with a hair dryer and getting the opening pick in there, with enough heat I could just slide the pick down the edges. Next time I’ll know better!
    Kirk Feindel - Replica
    I tried the heated iOpener. I had some success but then used too much force and cracked the screen. My advice is to take you time and use the iOpener often on the very edge of the screen. Use the suction cups or iSclack as your primary tools to separate the glass form the frame. And a second set of hands is very helpful to hold the metal part of the screen onto your table. The glass will come off with patience and perseverance.
    standurlacher - Replica
    Use heat, be patience don’t rush, go slow to prevent breaking screen like I did. I also damage the antenna to the wireless onboard adapter. The antenna is glued between the screen and the enclosure and is easy to damage. I didn’t realize this until after the repair was complete and my surface book no longer recognized its WiFi device. I have to use a usb/Bluetooth adapter. Good luck.
    Nyaniso Rahotep - Replica
    This is vital information - I also destroyed the antenna in the process, because the pick does not discriminate between layers of adhesive. . Microsoft did a horrible design job on this.
    Manuka -
    The WiFi antenna is not physically connected to anything. It has a capacitive interaction with a small brick below the plastic so you can build it by yourself with a 0.2mm foil of copper or aluminum, cut the same geometry and tape it . It works. iFixit guide is pretty incomplete about that point, without mentioning all the screws forgotten to mark.
    Gian Paolo -
    Best place of entry for the pick is by the speaker on the right and left side. Heat up that area and then get the pick through there. I found that pretty easy and sliding the pick around the bottom (where the tablet attaches to keyboard). Unfortunately, I broke the screen up top where the webcam is. Not sure if that area is more brittle than the others due to webcam, but word of advice is to be careful there. Using a hair dryer worked best and getting this very toasty; the iOpener was useless.
    Quan Thai - Replica
    Both sides of the central block “camera-Mic” there are three FSP antennas. They are easy to cut off while using an opener tool because a part can stick to the LCD and a part on the shell. So pay attention! I did cut one! You can clearly see the three antennas position in the first picture of the step 11.
    Gian Paolo - Replica
    Screen also broke on me when doing the repair. Got about halfway down the side of the Surface when the screen cracked in half. I wasn't planning on replacing the screen while replacing the battery and was pretty upset when it cracked. But as someone else said the screen is a "cost" of replacing the battery.
    meh - Replica
  2. Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: passo 2, immagine 1 di 3 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: passo 2, immagine 2 di 3 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your Surface Book so it rests level between the suction cups.
    • Position the suction cups near the middle of the bottom edge—one on the front, and one on the back.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  3. Microsoft Surface Book Screen Replacement: passo 3, immagine 1 di 3 Microsoft Surface Book Screen Replacement: passo 3, immagine 2 di 3 Microsoft Surface Book Screen Replacement: passo 3, immagine 3 di 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Microsoft Surface Book Screen Replacement: passo 4, immagine 1 di 3 Microsoft Surface Book Screen Replacement: passo 4, immagine 2 di 3 Microsoft Surface Book Screen Replacement: passo 4, immagine 3 di 3
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the bottom edge.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Didn't worked for me. And the top suction cup is now broken where the anti-clamp and the suction cup unites. Even though, it was extermely difficult to keep the anti-clamp in place. The top suction cup will begin to move around and the anti-clamp will not stay vertical, going sideways or tilted. I ended up using a standard suction cup and finally could move forward. Also the anti-clamp gets very hot when used with a hair dryer, and touching it is almost impossible.
    Andrés Vettori - Replica
    going from middle didn't work for me, works better from one of the bottom corners.
    me160 - Replica
  5. Microsoft Surface Book Screen Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Microsoft Surface Book Screen Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Microsoft Surface Book Screen Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • The adhesive securing the screen is very strong. This step may take significant force and multiple attempts.
    • Apply a suction handle to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    The glass is extremely brittle, so do not keep applying too much upward force while clearing the adhesive, or it will shatter and make you yell at your dog!
    Mark Yeager - Replica
  6. Microsoft Surface Book Screen Replacement: passo 6, immagine 1 di 2 Microsoft Surface Book Screen Replacement: passo 6, immagine 2 di 2
    • Use the pick to slice all the way around the perimeter of the screen to separate the glue.
    • Do not insert the opening pick too far into the screen or you may cause damage to internal components.
    • Gently raise the screen but don't fully detach it until the cables underneath are disconnected.
    Be carful around the power switch and volume buttons when separating as the WiFi Arial is attached to the casing under the adhesive strip, second Arial is located further along the case about the same distance away from edge of cases as the power and volume button .
    steve Brock - Replica
    This^^^
    Use heat, be patience don’t rush, go slow to prevent breaking screen like I did. I also damage the antenna to the wireless onboard adapter. The antenna is glued between the screen and the plastic strip protecting camera and is easy to damage. I didn’t realize this until after the repair was complete and my surface book no longer recognized its WiFi device. I have to use a usb/Bluetooth adapter. Good luck.
    how to remove WiFi antenna im stucked at this step.
    Marko Kolar - Replica
    Not just only around the power switch and volume button, but the whole top. There are three antennas in the left, middle and right top of the display
    seddosenpai - Replica
    Don't just be careful around the power switch and volume button, but the whole top. There are three antennas in the left, middle and right top of the display
    There are three antennas in the left, middle and right top of the display.
    Be aware that the glue at the top is about 3-4 times deeper than it is at the sides and bottom.
    Ben - Replica
    You can use the replacement adhesive strips as a guide to how deep to go with your pick (you did get replacement adhesive strips, right? - iFixit store IF412-035-1).
    Be careful when removing the old glue from the back side of the screen. The black color is on that surface, and if you scrape it, you'll scrape through the paint leaving unsightly scratches that will show through the bezel when you're done.
    Ben - Replica
  7. Microsoft Surface Book Screen Replacement: passo 7, immagine 1 di 3 Microsoft Surface Book Screen Replacement: passo 7, immagine 2 di 3 Microsoft Surface Book Screen Replacement: passo 7, immagine 3 di 3
    • Begin by removing the ribbon on the right. With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
    Metal plates are difficult to remove. Must pry them off.
    Tommy - Replica
    I was not able to pry off the metal bracket, so I just propped up the screen with the ribbon cables attached while I carefully worked on the laptop
    Jeff How - Replica
    I was able to pull the plate off with my thumb nail. It comes off easily if you get the right angle.
    Marvin - Replica
    I used a blue tool with small scoop on the side opposite the tines to leverage the bracket off. Easily popped off that way, after a few attempts with the curved tweezers filed.
    Mark Kizilos - Replica
    This blue tool seemed to work best for me, as well as knowing the pry point is opposite of the tines.
    mavzerb -
    Is it just me that had extra ribbons?
    W Z - Replica
  8. Microsoft Surface Book Screen Replacement: passo 8, immagine 1 di 3 Microsoft Surface Book Screen Replacement: passo 8, immagine 2 di 3 Microsoft Surface Book Screen Replacement: passo 8, immagine 3 di 3
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
    • Remove the screen.
    Remove only the plug to the far right leave the ribbon cables and the clips alone What was confusing in this photo it looked like he removed the large ribbon clip, he did not. I did and busted the clip that secured the cable. I had to buy a new touch sensor board.
    Don’t make this mistake, look carefully before you do. Stop before going to far.
    James Foley - Replica
    I managed to bust my connector as well, despite trying like !&&* not to - awful design on microsoft's part, but the instructions really need to call out just how exactly one needs to remove these without destroying other components
    Manuka -
    James Foley, I've just done the same: busted the clip on the wide connector (had to detach the ribbon cables to replace a broken screen with a new one). Where and how did you find a replacement board?
    Dan Guralnik -
    I assume your talking about step 8. I removed all 3 ribbons easily. 2 had latches that need to be opened. I had the whole sensor out and seperated.
    More McCormack -
    I think I could have done this in less than 30 minutes since the computer back was bulging with the batteries swelling. To my surprise, the batteries were stuck to the back with black adhesive so the connector popped loose. Fearing that I had screwed up the connector, I plugged the computer into the new battery pack and found everything was working and the battery showed a full charge. TaDa. With my wife’s help holding the back, I used a hair dryer and wooden spatula to remove the old battery pack. Rather than trying to apply more adhesive to the edges of the back I used black electrical tape to keep it in place.
    Tom Strothers - Replica
    I did the screen and battery. Battery swelled and cracked the screen. Scariest part was heating the battery. Reading all the labels about possibility of fire. I heated the back and the old battery slipped right out. adhesive was still good so I put the new battery right in on top of it.
    More McCormack - Replica
    If you are replacing the screen, you will need to transfer the square/triangular board from the old screen to the new screen. This step/detail is missing.
    meh - Replica
Conclusione
Altre 27 persone hanno completato questa guida.
USF Tampa, Team 1-6, Sullivan Spring 2017 Membro di USF Tampa, Team 1-6, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G6
3 Membri
14 Guide realizzate
34Commenti sulla guida
It is very unlikely you will get this screen off without breaking it. Luckily, my customer only wanted the SSD out of the device so he didn't care if I damaged it. This screen is crazy fragile and the glue is very very strong. Do not do this job thinking you will likely not break the screen, unless you have done it before.
Kevin Yaniak - Replica
The only way to remove it without breaking it is to use good scotch tape and completely cover the screen with a minimum 4 layers of tape. This will keep the screen intact - but you still have to be very careful.
Michael Griffiths - Replica
That’s definitely not the only way. I just did it with a guitar pick and heat pad. After doing a ton of Surface Pro 3’s, I think this one is actually pretty easy in comparison.
austin -
I needed 3 hours for this, Did this the first time. There is everything glued. and real hard to not break the screen.
Dennis Reimer - Replica
Can you put the screen back on after removing it?
Alex Shinnerl - Replica
Yep, clean the old adhesive and apply some Tesa 4695 or 61395.
Ben -
If you have a cracked screen already and want to do this to replace with a new screen, is it as hard to accomplish?
Daniel - Replica
Did you manage to do it?
felipemb997 -
Where can you actually buy a replacement screen?
Bahadir Malkoc - Replica
Repair Parts Plus sells the screen with the option to buy the tools required to pry your old screen off and an option to buy a screen protector.
Chaasadahyah Johnson -
Is the back light/lcd for the Surface Book sealed? If I used isopropyl alcohol to weaken the adhesive, would it stain the back or anything? If anyone knows, please reply.
Victor Gonzalez - Replica
Seems as though there was another component that damage at the top of the screen when battery expanded and popped screen. Looks like maybe wifi antenna. Is this true and is that easy to add to the repair?????? Like it was under the factory adhesive
Peter Plott - Replica
Additionally, is the “processor” on the back of the screen removable? Can’t seem to find a screen with this attached. Not sure if that is the NVidia controller or what roll it plays. Thanks for any help.
Heat gun helps.
smithjamesd - Replica
My screen is separating from the chassis on my Surface Book - 1st gen. It is loose most of the way across the bottom and right side. The screen is still intact. I would like to complete the removal process and then reattach the screen. Is there a recommended adhesive?
Scott Robinson - Replica
Hi. My surface book One, has what seen 4 burn spots. 2 on top and 4 on each side. So what is the issue here? Battery burning out?
A
Arun K. Raina - Replica
The discoloration that appears on the Surface Book1 display is a direct result of the battery packaging expanding like a balloon causing pressure under the LCD screen thus making the display flex and bulge; as if you were to put a small airbag inside the unit and inflated it.
The battery needs to be replaced.
Rick Sanchez -
which glue did you use to stick the screen?
P Kumar - Replica
Surface Book One, the side of teh screen (LCD think cover) has just came off, I think I will just stick it in, but which Glue was/is used?
P Kumar - Replica
iFixit tutorials are great, but why do they always stop at the removal stage? Would be great to know which adhesives are recommended for the new screen!
Thomas - Replica
Hey did you ever decide on one?
mtheinsomniac -
Great description BUT pictures are wrong about opening side and IOpener position. That is on video too. In fact we must open on on-off button but not on connector side.
frantz - Replica
I just finished replacing the screen battery in my Surface Book 1705. Everything works and it is almost as good as news.
"Allmost" because I left out gluing two areas along the top of the screen because I didn’t dare removing all of the old glue there as there is some conductive material underneath (antennas?). Those area about 50mm wide and sit approx 1/4 in from the top corner. I cut the adhesive strips to avoid having two layers.
I orderer both the battery and the adhesive strips on ebay.
Jan Inge Sageie - Replica
To succesfully remove the screen without damage is totally doable, at least after getting some “help” from the swelling batteries. :-)
I used a small heat gun, guitar picks to keep the screen from the frame after cutting and some pieces of thin stiff plastic (from a card lamination kit) to do most of the cutting. Take your time and don’t go in too deep. About 5mm is enough along most of the sides and bottom. 10mm in the corners and along the top edge. There is a lot of stuff along the top edge (the two conductive strips and a partially loose lens) so care care.
Removing the old battery was a PITA. I think that you should just take the board completely out. Unless your are not too ham-fisted, that is not too difficult. There are two small ordinary white plugs for the speakers and the other two closer to the hinge are pressed on like the two connectors to the screen.
I did two mistakes during assembly. The first (and huge one) was not to disconnect and remove the main camera (the one in the corner). Because of that, I didn’t notice that the powerswitch “button” was resting on the egde of the button in the frame and I managed to break the switch on the board when I put the screw in. :-( To replace the button took some time and it ended up costing a lot more than the battery and adhesive strips. Since I don’t have the equipment and experience in micro soldering SMD, I had to send it away for this job. The second mistake was not to make sure that the orientation of the two magnets along the edge of the screen was correct. Luckily, I loosely taped the screen to the frame for the initial test and actually tried to attach the pen. I got that sorted before removing the protective film on the adhesive strips.
After being super happy getting the screen battery replaced and my Surface Book back in business, I dicovered that I probably have the same problem with the other batteries in the base. :-( ifixit, YouTube and ebay once more…
I did the screen replacement, moved the touch controller and connected the ribbons but when I turned on the PC, the screen doesn’t receive any signal and stays black. I can see windows is loading as cameras turn on (windows hello) scanning for me. Moreover when I connect to an external display all is good and I can verify touch is working. I’ve tried both with the new screen and the original (broken) one but the result is the same.
While I was waiting for the screen to be delivered I used the computer with an external monitor for some time and the cable was exposed to air and potentially dust for a month.
I suspect it might be the LCD ribbon but I don’t remember any special interaction with it and visually it looks perfect, apart from being flexed in a few places. Any help would be appreciated.
Yavor Yanev - Replica
Same problem here! Did you find any solution?
Oliver -
I am having the same issue. Did you have its root cause?
Xinhua Zhao -
if I'm only upgrading the SSD drive, how can I put the same screen that was removed back in place?? Where can I find the adhesive? tips for completely removing the old adhesive?
Javier - Replica
What glue do you suggest for the replacement screen to be stuck back down with - where could that be purchased?
Thanks
Mike Bridge - Replica
For those interested, I believe the only way to remove the screen is with a heat gun. The ifixit (iopener) bearing can't even get to 100 degrees and the side where the camera sits is so full of adhesive that I had to work on it for at least two hours. The temperature I used is 200 degrees for 3 sides of the screen and 220 degrees Celsius for the side with the camera. Surely if I had been more experienced I could have increased the temperature up to 280 degrees but I was afraid of burning the screen. Another tip: when you have enough space to loosen the screen, carefully remove the adhesive on the side of the camera, perhaps with tweezers and help yourself to force it, but without exaggerating, with a suction cup.
Carlo Piras - Replica
This thing has the most impressive ability to dissipate heat I've ever seen. I used an anti-clamp, but the glass is SO flexible that I had to start at a corner and heat for a half an hour before any adhesive released.
Mike Schader - Replica
Hi, I need your help !
I replaced my touch screen on my Surface Book 1. I connected both connectors but nothing seems to work. My keyboard lights up but nothing on my screen. can you give me your opinion on what is not working please?
Chantal Murray - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 261
Tutti i Tempi: 55,994
