Salta al contenuto principale
Mac mini Model A1176 CPU Replacement
Cosa ti serve
  1. Mac mini Model A1176 CPU Replacement, Top Housing: passo 1, immagine 1 di 2 Mac mini Model A1176 CPU Replacement, Top Housing: passo 1, immagine 2 di 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    A spackle knife makes these steps go much faster.
    jouniseppanen - Replica
    A double sided letter opener or a thin non-serrated butter knife will suffice.
    To prenent cosmetic blemishes, place a matchbook cover or similar thin cardboard on the outer perimeter under the “jimmy”.
    Mike - Replica
    Despite mentioning recommended tools at the top I think it’s really worthwhile making a point about narrow Philips screwdrivers at this point before people start putting the case apart.
    Matt D - Replica
  2. Mac mini Model A1176 CPU Replacement: passo 2, immagine 1 di 3 Mac mini Model A1176 CPU Replacement: passo 2, immagine 2 di 3 Mac mini Model A1176 CPU Replacement: passo 2, immagine 3 di 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Patience is your best friend.
    Do not insert “jimmy in too far. Marking a line from tip upwards on the tool will prevent too far insertion, possibly breaking tabs or damaging internal components.
    To prevent the cover closing back up, small strips of matchbook cover (os equivalent) can be inserted about half inch hold prevent closure.
    Mike - Replica
    I think it needs to be made more clear that what you want to be doing is applying upward pressure on the back I/O panel with your HAND while pressing the clips with the jimmy, sort of like tensioning a lock and then setting individual tumblers. (Yeah, I watch LockPickingLawyer.)
    The pictures appear to show trying to lift the lower housing using the jimmy, similar to how I've seen people doing things like prying with a putty knife or screwdriver... and that plastic is only going to get more brittle over time.
    If you apply the upward pressure with your hand via the back panel and then work your way around the outside edge clip-by-clip, then it's much easier to be gentle with the jimmy because your only goal is to press on each clip enough to release it. All the rest of the force comes from, say, a finger hooked into the edge of the Ethernet port and a thumb pressing on the edge of the top cover.
    ssokolow - Replica
  3. Mac mini Model A1176 CPU Replacement: passo 3, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 3, immagine 2 di 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 CPU Replacement: passo 4, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 4, immagine 2 di 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 CPU Replacement: passo 5, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 5, immagine 2 di 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 CPU Replacement: passo 6, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 6, immagine 2 di 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Before reassembly, make sure no wires are sticking out.
    Line up top cover carefully. Gently press down on top cover until top and bottom fully seated.
    CAUTION! DO NOT PRESS TOO HARD ON THE COVER TO PREVENT CRACKING THE PLASTIC TOP.
    GO EASY.
    Mike - Replica
    Re: reassembly, I found it gentler to use the jimmy to lightly press the plastic clips in a little bit to get them past catching on the frame with minimal force.
    ssokolow - Replica
  7. Mac mini Model A1176 CPU Replacement, Internal Frame: passo 7, immagine 1 di 3 Mac mini Model A1176 CPU Replacement, Internal Frame: passo 7, immagine 2 di 3 Mac mini Model A1176 CPU Replacement, Internal Frame: passo 7, immagine 3 di 3
    • Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
    • First remove the AirPort antenna (the larger of the two), located near the power button.
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
    How serious is it if W1 loses the spring? Mine pinged off and I cannot find it. I spent about half an hour looking with no success.
    Matt D - Replica
  8. Mac mini Model A1176 CPU Replacement: passo 8, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 8, immagine 2 di 2
    • Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
    • The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
    Now also lift the right side of the ZIF cable lock up from its socket.
    chriZ - Replica
    Good catch of the incomplete unlocking instructions. ;P
    lamarhavard -
    Hmmm... what if I didn't read this before and I removed the cable and the lock sort of broke?... what would happen... would I experience problems? I can still put the cable back in place and push the lock back down with the spudger.
    Dan O - Replica
    Same. I totally removed the lock , the edges are busted and won't stay in place, How can I get the cable to stay? what's the fix?
    Suzanne -
    Dan O & Suzanne, hold the cable in the socket and put a dab of hot glue on both sides, It's non-conductive and should hold...worked for me.
    lamarhavard -
    does any one know, where to get the connector from zhe ZIF Cable?
    someone, that preowned my mac broke the holder!
    julian gmeiner - Replica
    Julian, did you ever find where to get a replacement lock for the Zip Cable. Mine is also broken..
    Suzanne -
    This is not my first memory replacement in a Mini and I got over-confident and stupidly fully removed the audio cable ZIF lock and assumed I had broken something. But, now that I have read this guide more carefully, I am not sure. I sure would love to hear some detailed instructions for putting a ZIF lock back on.
    Is it possible that I have removed it without having broken it? If I have broken it, do I have to buy a new cable? Just a new ZIF lock? A new audio board? This is a 2.0 GHz A1176.
    Thanks!
    GalvanicMacPro - Replica
    Michael, Mine seems to be broken. I bought & tried the Kapton Tape that was suggested & still no sound.
    Suzanne -
    C’est la première que je doit déverrouiller un câble ZIF. Je précise qu’il faut lever à gauche et à droite, ça force un peu, prendre appui sur le boitier du Mac, comme e montre la photo.
    La partie noire reste dans la partie blanche (+1 mm), et la nappe flexible sort par le haut.
    Ludovic - Replica
  9. Mac mini Model A1176 CPU Replacement: passo 9, immagine 1 di 1
    • Lift the audio board ribbon cable up out of its socket.
    • If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
    As an option to avoid potential damage when disconnecting the cable from the ZIF socket and clip, it is possible to unscrew the audio board and remove it along with the internal frame.
    Nick Baldwin - Replica
  10. Mac mini Model A1176 CPU Replacement: passo 10, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
    • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Use tweezers to grab the connector (as seen in the picture), not the wires.
    • The connector is located under the optical drive opening, next to the PRAM battery.
    Managed to leave this connected by flopping back the drive rather than totally removing
    pglock - Replica
    WATCH OUT!!
    separated one of the wires from the connector very easily. i would have preferred to use a spudger at this step. the tweezers in effect snipped the wire!!
    mklsvg - Replica
    As my experience you should definitely use angeled tweezers as shown in several pictures. To avoid stripped cable deflash sharp edges of the tweezers a little bit. I never experienced problems when using that kind of tool carefully.
    Timpetou - Replica
    I've had to remove a few of these connectors on iBooks and other small Apple devices ... I've found that, with careful and gentle pressure (working first one side and then the other) using a small flat-headed jeweller's screwdriver is best.
    Mike Haines - Replica
    I agree Mike.
    dixieskettlecorn -
    Note where the airport antennae connecting wire comes out from the interior along the top. When reassembling, it has to be routed the same way, or it won't reach its install position.
    robert - Replica
    If your fan runs at high speed after you complete this project, you have forgotten to reconnect the thermal sensor.
    Curt - Replica
  11. Mac mini Model A1176 CPU Replacement: passo 11, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 11, immagine 2 di 2
    • In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
    • Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
  12. Mac mini Model A1176 CPU Replacement: passo 12, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 12, immagine 2 di 2
    • Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
    • This screw is the longest of the four screws securing the internal frame to the bottom case.
  13. Mac mini Model A1176 CPU Replacement: passo 13, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 13, immagine 2 di 2
    • Remove the Phillips screw from the internal frame near the Bluetooth antenna.
    Before removing any of these screws, there is another step needed which is not here:
    On the front of the optical drive, right side as you look at the slot-load, is a small blue board attached by a single black screw. This needs to be removed before the optical drive can be taken out.
  14. Mac mini Model A1176 CPU Replacement: passo 14, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 14, immagine 2 di 2
    • Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
    On reassembly, if you don't have a magnetic screwdriver, a tiny dab of grease at the tip of your screwdriver will help hold the screw on the driver so you can lower it into the recessed slot.
    pfbloom - Replica
  15. Mac mini Model A1176 CPU Replacement: passo 15, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 15, immagine 2 di 2
    • Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
    • It may be necessary to pull up near the interconnect board to separate it from the logic board.
    At this point be careful that you don't pull out the Airport antenna ... but if you do, just check that it is back before re-assembling.
    During re-assembly, the internal frame has to go in at an angle ... the back of the optical drive goes in first.
    This means that you can seat the fan cover correctly, but more importantly, there is an interconnect board on the back of the optical drive that must be firmly pushed back into its housing on the logic board.
    Reassembly: Before slipping the main frame back into its place, refer to earlier photos, ensuring proper routing of the WiFi cable.
    Steve - Replica
    If, like me, you pull the wire on the airport antenna free, it snaps back into place easily. The connector is on the extra card screwed to the motherboard that looks like it has a phone battery embedded in it. The connector is at the top of the 'battery'. This accessory card is the wifi card, so it makes sense that the antenna plugs onto this.
    Dan - Replica
  16. Mac mini Model A1176 CPU Replacement, Logic Board: passo 16, immagine 1 di 1
    • Firmly grasp the power button cable connector with a pair of tweezers and lift it straight up off the logic board.
  17. Mac mini Model A1176 CPU Replacement: passo 17, immagine 1 di 1
    • Firmly grasp the sleep light cable connector with a pair of tweezers and lift it straight up off the logic board.
  18. Mac mini Model A1176 CPU Replacement: passo 18, immagine 1 di 1
    • Remove the single T10 torx lug securing the logic board to the bottom housing.
    I think a T15 fits better
    Marius137 - Replica
    Agreed, T15 is a better fit
    jouniseppanen -
  19. Mac mini Model A1176 CPU Replacement: passo 19, immagine 1 di 1
    • Use the flat end of a spudger to slightly lift the logic board near the PRAM battery to separate it from the bottom housing.
    • It will be necessary to gently pull the sleep light (shown in red) away from the mini to clear the edge of the logic board.
  20. Mac mini Model A1176 CPU Replacement: passo 20, immagine 1 di 1
    • Gently lift the free end of the logic board and wiggle the board as you pull it away from the I/O ports.
    Hi, when re-assembling, if you find resistance to the board sliding right up to the rear panel make sure that the spring finger on the casing goes over the power connector not inside it. It fits much better that way!
    Adrian Berry - Replica
  21. Mac mini Model A1176 CPU Replacement, CPU: passo 21, immagine 1 di 2 Mac mini Model A1176 CPU Replacement, CPU: passo 21, immagine 2 di 2
    • Before removing the processor you must first remove the aluminum heat sink.
    • To avoid bending the fins, don't squeeze the upper portion of the heat sink perpendicular to the length of the fins.
    • A spring loaded plastic pin at each corner of the heat sink holds it firmly against the face of the processor.
    • The pins have barbs at one end that expand once the pin passes through the logic board. The barbs must be squeezed together to fit through the holes in the logic board. Use extreme caution when squeezing the barbs together with pliers near the exposed face of the logic board.
    Be careful to not break the nylon pins during removal or insertion. The strength of the spring can break the barbed end off the pin.
    Also, be sure to orient the heat sink in the right direction when putting it back. The fins should allow air to flow towards the openings at the back of the Mini (where the ports are).
    Matthew Wagner - Replica
  22. Mac mini Model A1176 CPU Replacement: passo 22, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 22, immagine 2 di 2
    • This step requires working with both hands and may be better accomplished with the logic board sitting in your lap.
    • Using a plastic opening tool (or similar) in one hand, push down one pin holding the heat sink on the logic board. The spring under the pin will provide moderate resistance.
    • While holding the pin down from the heat sink side of the board, use a pair of pliers in your other hand on the underside of the board to squeeze both barbs against the plastic shaft of the pin.
    • With both barbs squeezed together, push the pin through its hole in the logic board.
    • Repeat this process for each of the four pins holding the heat sink on the logic board.
    I busted the little expansion fins on 2 of the four plastic connectors here. I was gentle, but they are brittle buggers. Heads up.
    Tim Hirzel - Replica
    Oh, and then I busted the other two trying to put them back in! They are 3+ years old, and seem to break quite easily. I looked from nylon fasters at the hardware store, but couldn't find small enough ones. I had some small stainless fasteners, and made sure they were only touching the grounded material. I don't know if I recommend it, but all is well for me. I kept the spring in, and just put a washer a nut to hold the spring down. Try to do the operation in a small room so when the posts and springs go flying, you don't have many square feet to cover to find them. I spent a good portion of the upgrade time crawling around on the floor looking for a lost spring...
    Tim Hirzel -
    The springs holding the nylon pins are stronger than you might think.
    Use the finest tip needle-nose pliers you can find. The trick is compressing *and* pushing at the same time.
    Around 2mm or so from the surface of the circuit board is the furthest point at which the barbs can be compressed sufficiently to pass through the hole in the board.
    If you grasp the barbs closer to the circuit board, you won't easily be able to push the pin through the board.
    garyobrien - Replica
    Adding to my note, the illustration for Step 21 is a bit misleading. You'll have to grab the barbs much closer to the end of the pin than is shown here.
    I also broke one of the winged pins and replaced it with 4-40 Nylon machine screws and brass nuts I bought from McMaster-Carr. They are #94605A115 and #95130A110 respectively. Also, to press on the pins while squeezing the wings while holding onto the board is a challenge. I found a removable eraser from a mechanical pencil works great to press as it fits down into the heat sink just enough to be self stabilizing so one had presses and holds while the other just deals with the wings.
    terryandbonnie - Replica
    Thanks for those McMaster-Carr item numbers!
    I was just giving my ancient Mac mini a much-needed deep cleaning and re-greasing, and broke two of these posts, sending one of the springs across the room - whoops!
    Replacements on the way...
    Jolly Roger -
    Do yourself a favor and just accept the fact that these little buggers WILL break and that you will need to find replacement nylon screws and bolts. A quick google shopping search for "Mac Mini Nylon Screws 4-40 X 3/4" should pull up what you need -- I found an ebay listing for $3.99 USD!
    Even if you somehow manage to keep the pins intact during this step, realize that getting the heat sink back on is an even harder task in my opinion.
    I found it easier to have another individual assist here -- one to securely push down the pin on one side and the other to firmly grip and squeeze the barbs. Don't underestimate the strength of the springs. The pin and spring can go flying if either end is not secured properly.
    William Adan - Replica
    Mechanical pencil eraser does work perfectly to press pins. Let's you control the board and the pin with one hand while manipulating the barbs with the other. I found that a straight hemostat worked really well in place of pliers. Squeeze the barbs as near to the end as you can, then push them into the hole until they're wedged. Use your fingers or a spudger to push them the rest of the way through so you don't endanger the logic board with a metal tool. Got all four of mine out and back in intact, all in about five minutes. If the barbs don't break off, there is no danger of the pins flying because of the spring -- they are captive on the heatsink.
    Roger Mercer - Replica
    the pencil eraser is a great pro-tip! i aligned the flat part of a spudger with the notch in the heatsink fins and that worked pretty well, along with distributing any load across a pretty large surface area. a pencil eraser would have been perfect!
    R Henning -
    I came across some heatsink push pins in the Farnell catalog and tried them. Wish I hadn't bothered - although they are *just* about long enough, I only managed to get one to connect, the other three just refused to lock. Getting M3 bolts from ebay. Hope I haven't broken the CPU / PCB in the efforts to get the push pins in.
    daves - Replica
    Hi, I managed to do this by just using fine, flat ended pliers to squeeze the barbs. I went end on to the pin head instead of from the side. Didn’t need to press on the heat sink side at all. A slight wiggle and the spring just pulled them through. Dead easy and didn’t break one on a 7 year old machine!
    I didn’t break a pin, but I managed to knock a resistor (R4150) off the board, and then promptly lose it while trying to reattach it. Hopefully it’s not actually vital, as some parts aren’t … (Later: Boots fine, seems to run fine, with the new CPU. So whatever R4150 does, it’s not *100% obviously, immediately necessary*.)
    Sigivald - Replica
    A screwdriver bit set I got years ago from some Chinese web shop had the perfect tools for this: a screwdriver shaft that was thin enough to push the pins, and what appears to be a 2.5mm hex nut driver for the other side. Just pushing the pin into the 2.5mm slot and wiggling for a second or two did the trick. (I don’t know if that’s any standard size, but it was labeled M 2.5 and the opening seems to be approximately 2.5mm. The 3.0mm bit was too large for this purpose.)
  23. Mac mini Model A1176 CPU Replacement: passo 23, immagine 1 di 1
    • The heat sink is still attached to the logic board by the thermal sensor cables.
    • Lift the heat sink off the processor and lay it on the AirPort card.
    When I got to this step, I had trouble pulling up the heat sink. I even double and triple check to see if anything was holding it down. I used force but was able to get the heat sink out. The CPU was attached to the heat sink and the CPU was still in the lock position . It looked like there wasn't enough thermal paste and the CPU sealed itself to the heat sink. I was able to scrape off the CPU from the heat sink using the iSesamo to gently pry around the perimeter. When the CPU was off there was residue on the heat sink that I was able to clean off with a razor blade. Before placing the heat sink on top of the new CPU, I did do the "tinting" process to make sure the sticking wouldn't happen again. Not that I want to open up this box again!
    Nick - Replica
  24. Mac mini Model A1176 CPU Replacement: passo 24, immagine 1 di 3 Mac mini Model A1176 CPU Replacement: passo 24, immagine 2 di 3 Mac mini Model A1176 CPU Replacement: passo 24, immagine 3 di 3
    • Use the tip of a spudger to push the heat sink thermal sensor connector out of its socket.
    • It may be necessary to work from alternating sides to 'walk' the connector out of its socket.
    • Remove the heat sink and set it aside.
    This connector is actually a "locking" connector - the small slot in the middle of the jack (visible in the picture) is where a protrusion on the plug actually "locks" the plug in place. One may need to use a small / thin flat blade screwdriver inserted against the top of the plug to gently pry the jack housing up while at the same time pushing the plug down and sliding the plug out. I realized this after breaking the plug following the listed instructions...
    Better yet - this step and step 30 should really just be eliminated - there isn't any reason to unplug the sensor - its not in the way of changing out the processor.
    Murray Pickard - Replica
    Agree with “just leave the sensor connected”. There’s no need to remove it.
    Mark Barnes - Replica
  25. Mac mini Model A1176 CPU Replacement: passo 25, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 25, immagine 2 di 2
    • To unlock the processor, use a small flathead screwdriver to rotate the processor lock 180 degrees counter-clockwise until the indicator is near the open lock symbol.
  26. Mac mini Model A1176 CPU Replacement: passo 26, immagine 1 di 1
    • Grab the processor by its edges and lift it straight up off its socket.
    • Rotating the processor while lifting it out has the potential to break pins off inside the socket. Lift it straight up.
  27. Mac mini Model A1176 CPU Replacement: passo 27, immagine 1 di 3 Mac mini Model A1176 CPU Replacement: passo 27, immagine 2 di 3 Mac mini Model A1176 CPU Replacement: passo 27, immagine 3 di 3
    • Processors are extremely sensitive to electrostatic discharge. Only handle your processor by its edges.
    • To aid in installation, processors and sockets have a small alignment arrow (shown in red) so the chip is installed in the correct orientation.
    • Align the chip so that the arrow in its upper right corner corresponds to the arrow molded into the upper right corner of the socket.
    • Carefully lower the processor onto its socket.
    • Note that if you are upgrading from a core solo or core duo processor to a core 2 duo processor and wish to run operating systems of Lion or later, you must delete the hidden file /System/Library/CoreServices/PlatformSupport.plist after the upgrade.
    Hellp how and where do I delete this file
    Thomas - Replica
  28. Mac mini Model A1176 CPU Replacement: passo 28, immagine 1 di 1
    • Use a small flathead screwdriver to rotate the processor lock 180 degrees clockwise until the indicator points toward the closed lock symbol.
  29. Mac mini Model A1176 CPU Replacement: passo 29, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 29, immagine 2 di 2
    • Now that the processor is in place, turn your attention to the heat sink.
    • Apple uses a thermally conductive film that must be removed prior to reinstalling the heat sink.
    • Use a razor blade (or anyother flat object such as a credit card, etc.) to remove all of the old solidified thermal material from the heat sink.
    • Next use a small amount of rubbing alcohol to remove all traces of the old thermal material.
    • Allow the heat sink to dry before proceeding.
  30. Mac mini Model A1176 CPU Replacement: passo 30, immagine 1 di 1
    • Apply a thin layer of thermal paste to the reflective silicon face of the processor.
    • Check out our thermal paste guide for detailed instructions on applying thermal paste.
  31. Mac mini Model A1176 CPU Replacement: passo 31, immagine 1 di 1
    • Lay the heat sink on the AirPort card and use a spudger to reconnect the heat sink thermal sensor.
  32. Mac mini Model A1176 CPU Replacement: passo 32, immagine 1 di 1
    • Position the heat sink the same way it will permanently sit before lowering it onto the processor to avoid spreading thermal paste on regions not in contact with the processor.
    • Gently lower the heat sink onto the processor.
    Forget all the original plastic posts. I bought M3x20 (Sorry, I just know the measures of the "metric world" ;-)) plastic screws and according nuts in an ordinary DIY superstore. They fit perfectly. When fixing the heat sink it is recommended to get help from a second person. You should place the screws with springs from the upper side down through head sink and logic board with one hand while you simultaneously press on the heat sink on the processor. (Avoid canting it!) The helping person just tightens the nuts downside the logic board. Needless to explain that you should fix the screws diagonally.
    Timpetou - Replica
    You could probable get by with two small zip ties to hold it in place for each that break.
    George Tedrick - Replica
    I got three of the nylon pins back in and the *last one* snapped part of the split end off. I just want to add a “me too” to the M3x20 nylon screw and hex nut solution. Re-use the spring and tighten to the same length as the original pins and you should be good to go. I did all four so I don’t have to re-live that ever again.
  33. Mac mini Model A1176 CPU Replacement: passo 33, immagine 1 di 2 Mac mini Model A1176 CPU Replacement: passo 33, immagine 2 di 2
    • While holding the heat sink in place, press the four plastic posts down through the logic board to reattach the heat sink.
    Hi, I found that a slight wiggle while pressing down helped the pins slip through the holes
    I have watched a lot of you tube tutorials until i discovered this. This is the best instructional step-by-step so far. Excellent!
    dinand_beltran - Replica
Conclusione
Altre 171 persone hanno completato questa guida.
44Commenti sulla guida
I'm learning from cpu-world.com that the Core Duo (and Core Solo) are 32-bit architecture, whereas the Core 2 Duo is a 64-bit design. Does this matter in any way?
Richard - Replica
Hi Richard. I realize this post is very old, but did you ever get an answer to your question as to whether the 64-bits of the Core 2 Duo Processor will be recognized/utilized in the 32-bit architecture of the Mac Mini A1176? Thanks, John
John Trevett -
Hi. I'm afraid I can no longer answer the question "does it matter in any way", since I eventually upgraded to a new Mac Mini.
I can say that it didn't *seem* to matter, which means no software failed to run or performed noticeably poorly because of the upgrade. But I'm not especially performance sensitive, so it is possible that all/most/some software was running in 32-bit mode and not taking advantage of the higher throughput of a 64-bit architecture. The most CPU intense stuff I was running when I decided to upgrade was: Parallels running WinXP and some Windows-only legal software, along with Chrome with far too many tabs open, and iTunes. That proved to be too much, and it'd slow to a crawl too often. But I think the upgrade kept me on that iMac and extra two or three years, and was an interesting exercise.
Richard -
Hi, the processor will work just fine, but it’s recommended to do an EFI upgrade from 1,1 to 2,1, then you can run Lion and unofficially newer OSes
Arek Plewa -
When going to all the trouble of replacing the CPU, a few other upgrades can be done at the same time:
- Upgrade RAM to 2GB maximum (required for OS X Lion), for example, Crucial CT541128
- Upgrade internal 2.5" SATA hard drive to larger size, and/or faster 7400 RPM or SDD.
- Replace PRAM battery with a fresh one (CR2032 lithium 3V)
Jake Errs - Replica
What would be wise
Ben Capehart -
This guide worked very well for me. Entire process took less than 90 minutes, and that was having to pull the upper frame a second time because I'd let the Airport antenna cable get snagged under the fan ductwork.
Thank you!
Without a spatula I resorted to a Pizza cutter. It worked perfectly as it has a bevelled edge and was easy to move across the side to loosen the clips.
Phil Millard - Replica
Great idea - a pizza cutter worked great for me too!
pfbloom -
I too used M3 nylon screws and nylon nuts for the winged pins I broke during reassembly
I only got 30mm and cut it to about 20mm.
On the second A1176 where I removed the heat sink I didn't bother to remount the pins and used 4 nylon screws.
A special note: The second A1176 was much louder and got hot (fan running full speed) easily. When I removed the heat sink I found a die sized piece of plastic between the die and the thermal paste. Someone forgot to remove it when the Mini was assembled originally.
ste - Replica
hello, core 2 duo model I can use to upgrade my mac mini
Daniel Ilich - Replica
After upgrading to a Core 2 Duo (64-bit)
is it possible to install OS X 10.9 Mavericks ???
Sascha Faller - Replica
Exactly! Not seen an answer!
Simon Long -
Hi! You actually can using SFOTT or MacPostFactor, but you’ll struggle to find a GPU driver (they do exist tho)
Arek Plewa -
Whats the biggest processor you can put in this?
Jody - Replica
hi. Intel(R) Core(TM)2 CPU T5600 @ 1.83 Ghz may have the highest what Ghz number of
Mustafa -
Core 2 Duo T7600 (Merom) - 2.33 Ghz is the top of the range that will fit in a Mac Mini 1,1 or 2.1
David Chmielewski -
There are two important points about which Core2Duo CPUs can be used:
1. socket 'M' (not 'P' or other variants sold with the same type)
2. FSB speed 166 MHz = 667 Mt/s (not faster or slower, as it can't be set in BIOS)
This leaves few choices (the 'T' and 'S' identifiers are on the upper label):
- T5500 / SL9SH or SLGFK or SL9U4 (all 1.66 GHz)
- T5600 / SL9SG or SL9U3 (both 1.83 GHz)
- T7200 / SL9SF (2 GHz)
- T7400 / SL9SE or SLGFJ (both 2.17 GHz)
- T7600[G] / SL9SD or SL9U5 (both 2.33 GHz)
The 'T7' ones are preferable because of 4 MB L2 cache (others offer 2 MB) - clock speed is less crucial.
I didn't test all CPUs, got data from spec lists.
akronymus -
Went through the process well, but when i got to booting my mac mini it did not display pictures. i went through the dismantle again and changed everything back to basics but still do not have anything besides a power on. help!!
Matthew Harbort - Replica
Make sure you replace the PRAM battery, Macs with integrated graphics can lose video if this is flat/missing
Rob Stearn -
Thanks Rob - it is always a good idea to replace this quite cheap but important battery when such a machine is opened once. They keep the internal clock holding time / date, and when this is faulty, some models even refuse to start up.
akronymus -
Thanks, completed the guide and it works brilliantly! 1.5 core solo to 1.83 core 2 duo.
Chris Gollop - Replica
I have mac mini 1.1 with 1.5 single core CPU in it. I was planning to upgrade to Core 2 Duo T7200 and from 512 to 2Gb ram. Do I have to flash EFI if I upgrade 2Gb and that processor or that flash is only if you want more than 2Gb ram ?
The Scientist - Replica
Brilliant tutorial.... just upgraded core solo1.5 to core 2 duo 2.0. 30mins tops...
scott turkington - Replica
What is the max os X that can run on this improved machine?
Mark - Replica
Officially 10.7.5
Riccardo -
What's the max osX that can run on this improved machine?
Mark - Replica
i've followed this guide and replaced CPU ram and hdd. I've switched the mac mini on and the system booted in few seconds, cpu and ram recognized. But after less than a minute it switched off by himself and I've never been able to switch it on again. No fan noise, no light, no chime, nothing. I have even tried to put the old cpu and ram back but no luck. It seems completely death. Any suggestion?
Massimo Di Leo - Replica
Were you able to get it working again?
Christopher Engell -
hi there, can i put an intel t7500? or an intel t5450? wich one you recommend?
oviedosantiago - Replica
Careful - there is a chaos about different sockets (must be »M«), and the FSB speed must be the same as of the originally built-in processor.
akronymus -
Can anyone provide an answer as to which OSX system version you can upgrade to when upgrading the processor as described? What would be the latest version?
Marco Flores - Replica
Dear I WOULD LIKE TO CHANGE THE CPU FROM T7600 2,20 gHZ with A T9500 INTEL 2.5 gHZ
who can tell me if it works??
thanks a lot to you all
I have this product: Apple Mac mini "Core 2 Duo" 2.0 features a 2.0 GHz Intel "Core 2 Duo" (T7200) processor,
a 4 MB on-chip level 2 cache, a 667 MHz frontside bus,
4 GB of 667 MHz DDR2 SDRAM (PC2-5300) memory,
a 5400 RPM, 120 GB Serial ATA hard drive,
, an "Intel GMA950 graphics processor with 64 MB of DDR2
ilbulga - Replica
I’m no great expert, but the T7600 is socket M and the T9500 is socket P so I would say this will not work
David -
As David notes, socket M and socket P aren't the same. If you want to spend a lot of effort on it, Google their differences. The Wikipedia page for Socket M points to a CPU-World article that states there’s only a single pin difference, but for most of us that is a plenty big barrier.
Richard -
IMPORTANT WARNING: If you’re doing a processor change in 2018, keep in mind that all those plastic/nylon pieces inside the mini have had years of exposure to heat, and will have become very brittle by now. The connector for the ribbon cable to the optical drive, the clips holding in the heatsink, and most dangerously of all, that tiny connector for the temperature sensor are all at risk to become extremely brittle. if you can manage to not disconnect the heatsink sensor, you might be better off. Also, while you’re getting that new processor, think about getting new fasteners for your heatsink.
This information comes to you by way of personal experience.
Bill - Replica
For removing the plastic clips of the CPU heatsink, I found that the tool to remove pins from a molex connector was perfect and avoided any risk of pliers slipping and gouging the logic board.
https://www.ebay.co.uk/itm/Computer-Wire...
Julian LeCircle - Replica
Haven’t done this yet but from what I’ve read, macmini should be able to take 4GB RAM after the EFI update:
Expandable to 4GB after Core 2 Duo upgrade and macmini2.1 efi hack
Download macmini1,1 -> macmini2,1 firmware update:
https://support.apple.com/kb/DL1616?loca... (Mac mini EFI will be updated to 0106.B03)
https://gist.github.com/dreamcat4/717273...
Pii - Replica
Hi I have upgraded A1176 cpu to 4gb and processor to 2.10ghz currently but when I try to upgrade osx snow leopard 10.5.8 to lion or elcapitan or any other os is not working always gets no supporting even mac post factor and sofpt are apps are not working kindly help in upgrade to latest
Praveen GB - Replica
Bonjour est il possible de remplacer par un i5 ou il svp
goodlife08 - Replica
Thanks for the guide - handy as always.
r.holmes - Replica
Wonderful - I’ve just upgraded from a CoreDuo 1.66 to a Core2Duo 1.16, and everything great.
I also did an EFI Firmware update and the system is now showing as MacMini 2,1 rather than MacMini1,1
https://gist.github.com/adur1990/adf36f9...
Will look to upgrading the RAM shortly, as the 2,1 can access 4Gb RAM and the 1,1 can only access 2Gb.
r.holmes - Replica
I tried to update a late 2006 Mac Mini to a T7400. All guides and forum entries state that the CPU shall be upgraded first. But after the upgrade the system won't boot anymore. No chime or other sign of life. I downgraded to the original Core Duo again and the system booted fine. As every guide states "do not start a firmware update without upgrading the CPU first" I don't know what to do...
T. Lang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 210
Tutti i Tempi: 227,921
