Mac mini (2024) CMOS Battery Replacement
Introduzione
Vai al passo 1Use this guide to replace the CMOS battery in your Mac mini (2024).
This CMOS battery is a standard 3V BR1632 coin cell battery.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Fully shut down your Mac mini and unplug all cables from it.
Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
Insert a Jimmy into the gap between the bottom cover and the chassis.
Pry up the bottom cover to create a gap.
Keep the Jimmy inserted under the bottom cover.
Insert an opening pick into the gap created by the Jimmy.
Remove the Jimmy.
Slide the opening pick along the bottom cover until you feel it snag on a clip.
Twist the pick to lift the clip out of its slot.
Grip the power button cable close to the head and pull it away from its socket to disconnect it.
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a Torx Plus 3IP screwdriver to remove the two 2.1 mm‑long screws securing the CMOS battery screws.
Lift the CMOS battery and its housing off the inner plate and remove it.
Use the flat end of a spudger, or your fingernail, to lift the CMOS battery out of its housing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
