Salta al contenuto principale
Mac Pro First Generation RAM Replacement
Andrew Kim
Andrew Kim e 3 altri collaboratori
Ultimo aggiornamento il 6 lug 2025
5 - 10 minuti
Facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Accessing the RAM is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
  1. Mac Pro First Generation RAM Replacement, Case Panel: passo 1, immagine 1 di 1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation RAM Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.16
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Locate the two RAM trays at the bottom of the Mac Pro.
  4. Mac Pro First Generation RAM Replacement: passo 4, immagine 1 di 2 Mac Pro First Generation RAM Replacement: passo 4, immagine 2 di 2
    • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
    • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
  5. Mac Pro First Generation RAM Replacement: passo 5, immagine 1 di 3 Mac Pro First Generation RAM Replacement: passo 5, immagine 2 di 3 Mac Pro First Generation RAM Replacement: passo 5, immagine 3 di 3
    • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
    • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
Conclusione
Altre 22 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Andrew Kim
Membro da: 10/12/14
1.263 Reputazione
3 Guide realizzate
Cal Poly, Team 6-24, Maness Fall 2014 Membro di Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membri
19 Guide realizzate
2Commenti sulla guida
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Replica
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 45
Tutti i Tempi: 21,116
