Salta al contenuto principale
Lenovo ThinkPad T470 Keyboard Replacement
Kristen Gismondi
Kristen Gismondi e un altro collaboratore
Ultimo aggiornamento il March 4, 2024
15 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to replace the keyboard in your Lenovo ThinkPad T470 laptop.
A properly functioning keyboard will register keystrokes on the laptop’s display. Functioning keys will pop back up to their normal position after typing and will feel securely attached to the keyboard.
A keyboard that is malfunctioning may only register some keystrokes (or no keystrokes at all) on the laptop’s display. Certain keys may get stuck when pressed down or keycaps may feel loose and wobbly when typing.
If you suspect that your keyboard issues are software-related, visit this PCMag article for more information.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Ricambi
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Lenovo ThinkPad T470 Keyboard Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T470 Keyboard Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T470 Keyboard Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
    To remove the trackpad/touchpad, you can skip a lot of steps here:
    4, 5, 6, 7, 8 are for removing the keyboard, which isn't required to swap the touchpad.
    14, 15, 16 are for removing the top RAM stick.
    22 to 41 are not required (so continue with step 42)
    44, 45, 46, 47 are not required either.
    So to replace the touchpad, do these steps:
    1, 2, 3, 9, 10, 11, 12, 13, 17, 18, 19, 20, 21, 42, 43, 48, 49, 50, 51
    tobi - Replica
  2. Lenovo ThinkPad T470 Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T470 Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T470 Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Lenovo ThinkPad T470 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Loosen the two captive Phillips #1 screws on the back cover of the laptop.
  4. Lenovo ThinkPad T470 Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T470 Keyboard Replacement: passo 4, immagine 2 di 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 Keyboard Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T470 Keyboard Replacement: passo 5, immagine 2 di 2
    • Place your fingers on the bottom edge of the keyboard.
    • Apply a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 Keyboard Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T470 Keyboard Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T470 Keyboard Replacement: passo 6, immagine 3 di 3
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T470 Keyboard Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 Keyboard Replacement: passo 8, immagine 1 di 2 Lenovo ThinkPad T470 Keyboard Replacement: passo 8, immagine 2 di 2
    • Use your hands to lift the keyboard up and away from the laptop.
Conclusione
Altre 4 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
93.005 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
121 Membri
19.812 Guide realizzate
1Commento della guida
Absolut BRAVO
Mega tolle kostenlose mit "lLiebe" hergestellte Anleitungen !
Bin 1979 auf dem 6502 mit dabei.
Dieses Dokument ist eine weitere
Bestätigung, das der Griff zu LENOVO' Produkte stehts die richtige Wahl war
wen es auch wie jetzt nur die suche nach den Befestigunsschrauben der Tastatur war.
Danke für die schöne Daus komp. Anleitung
S.Kopp
aus Luzern-CH
Stefan Kopp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 159
Tutti i Tempi: 7,453
