Salta al contenuto principale
Lenovo Ideapad 320-15IAP Battery Replacement
Franco Criscola
Franco Criscola e 4 altri collaboratori
Ultimo aggiornamento il February 24, 2024
5 minuti
Facile
Introduzione
Vai al passo 1
The purpose of this guide is to demonstrate how to replace the battery of your Lenovo Ideapad 350-15IAP. This replacement guide is very simple and requires very little technical knowledge to complete. In summary, you will be using a Phillip’s head screwdriver to remove the case of the laptop. The battery will be immediately exposed and can be removed by simply removing four screws.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: passo 2, immagine 1 di 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: passo 3, immagine 1 di 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 49
Tutti i Tempi: 1,552
