Salta al contenuto principale
How to Fix Logitech G403 Double Click Issue
Jisuk Kang
Jisuk Kang e 2 altri collaboratori
Ultimo aggiornamento il April 24, 2023
20 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to fix the mouse if there is a double click problem on your Logitech G403.
Double clicking is a very common problem for G403. If your warranty is finished, you can fix the mouse by yourself, rather than buy a new one.
You will need a precision screwdriver set to fix the mouse. However, in case your screwdriver doesn’t work, you can look at these pages for help:
Don’t forget to unplug your mouse before you start.
Cosa ti serve
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: passo 1, immagine 1 di 1
    • Use a prying tool or your hand to take out both sides of the mouse feet.
  2. How to Fix Logitech G403 Double Click Issue: passo 2, immagine 1 di 1
    • Use a precision screwdriver to remove four screws from the mouse.
  3. How to Fix Logitech G403 Double Click Issue: passo 3, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 3, immagine 2 di 2
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
  4. How to Fix Logitech G403 Double Click Issue: passo 4, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 4, immagine 2 di 2
    • Remove seven screws from the upper cover.
  5. How to Fix Logitech G403 Double Click Issue: passo 5, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 5, immagine 2 di 2
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
  6. How to Fix Logitech G403 Double Click Issue: passo 6, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 6, immagine 2 di 2
    • Remove the five screws attached to the mouse click switches.
  7. How to Fix Logitech G403 Double Click Issue: passo 7, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 7, immagine 2 di 2
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
  8. How to Fix Logitech G403 Double Click Issue: passo 8, immagine 1 di 2 How to Fix Logitech G403 Double Click Issue: passo 8, immagine 2 di 2
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
Conclusione
Altre 10 persone hanno completato questa guida.
Jisuk Kang
Membro da: 07/05/20
415 Reputazione
1 Guida realizzata
10Commenti sulla guida
step 8 made no sense and had to google it
rel - Replica
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López -
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Replica
I could not open these screws :( What are the screwdriver size to open these?
Siim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 57
Ultimi 30 Giorni: 297
Tutti i Tempi: 32,632
